I'm going to a tempt to build a frame or the rear bench out of square tube and angle. What thickness should i use? Is 1/8" not enough?
I have done a few sets for customers. It is easy to do the front sliders and takes about 4 hours to cut down and clean up and fab. We also have a tubing rear seat frame that we cad up that uses all factory seat mounts to bolt in either 1 bucket, 2 buckets, or bucket bench depending on customer request. Its all easy stuff just time consuming. The first set up we did cost about $100 in materials. Hers some pics I hope it helps.RyanDS650X wrote:Oh they are![]()
I think so too, ive got everything measured out, ill price material and give it a go.ChaseTruck754 wrote:agreed. tabs are easy to add if the base is set.
That one from Southwest looks pretty straightforward for even someone newer to fab. Simple yet strong. I'm sure you can bust something like that out Ryan.
