I love dimples but there is definitely over use and dumb looking use. Like Steve said, take a little weight and add some rigidity to a plate.
Ford 4 US
- Bronco Info: 96 and 79 (79 is a basket case right now)
Obviously not structural.... But remember louvers on cal bugs and mini trucks
Damn.... That went stupid......
I've seen the same thing on hot rods. I guess it's a "style" but seeing a rod with the entire trunk or hood louvered just kills it for me.
Ford 4 US
Now it is led lights.....
Pretty slick seat slider idea:
Notice the pull pin.
- image.jpg (174.85 KiB) Viewed 1714 times
Pete Albano's Ranger had a similar set up. So simple but genius. I like!
That is pretty trick!
What type of business is that on the slider?
That is how I want to do my sliders on the driver's side. The difference is I am going to use 2 pull pins on each tube. Also the tubes will use Delrin bushings to ride on. I would not trust a single pull pin.
From what the dude was saying those are delin bushings it slides on. I think id use oil lite bushings (bronze with impregnated Teflon dry self lubricating)
Poly Performance sells a premade slider like that.
http://www.polyperformance.com/shop/Cha ... 30567.htmlphilofab wrote:Poly Performance sells a premade slider like that.
That is something else. The one I have slides on 1" tube.
That's cool I liked it's adjustability and it looks strong, I'll check poly performance. As you guys know I'm a cheap ass but I'm also a lazy ass so if cost outweighs time spent I'd gladly buy a set.
My buddy did the tube sliders ones like the 1st pic long ago in the 1 car due to driver size difference. They are cool for sure, but you have to be sure the tubes you weld in to the cage are square & that they do not pull at all during weld up or the sliders don't work well at all
The Trophy Truck has those . The new Trophy Truck, has an actuator ! Push Button comfort !.
Yup! My Bronco now and even better! Did some upgrades since I bought it from Sean and i'll have pics up soon.cypher wrote:And yes it is Convoys old rig. It's a great bronco that Sean has made even better
Oil lite is impregnated with 30W oil.Rmc wrote:From what the dude was saying those are delin bushings it slides on. I think id use oil lite bushings (bronze with impregnated Teflon dry self lubricating)
Delrin AF would be My material of choice for those.
Brian, is that the grey silver-ish delrin? The stuff with the kinda reflective ground up looking stuff in it?
