RMC's el hefe build.
Re: RMC's el hefe build.
Come on, paint the Bronco Purple and get some hot pink Dingle balls for the window frame.
You could fiberglass in the rear side windows and have those diamond shaped windows put in. The ones that bulge out. Then a bitchen fire dragon fighting a half naked chick wizard airbrushed on the tailgate. Someone need to photoshop that.
Made me laugh.. I was totally picturing that in my head.Tchajagos wrote:You could fiberglass in the rear side windows and have those diamond shaped windows put in. The ones that bulge out. Then a bitchen fire dragon fighting a half naked chick wizard airbrushed on the tailgate. Someone need to photoshop that.
- 93Broncobuff
Rmc wrote:Made me laugh.. I was totally picturing that in my head.Tchajagos wrote:You could fiberglass in the rear side windows and have those diamond shaped windows put in. The ones that bulge out. Then a bitchen fire dragon fighting a half naked chick wizard airbrushed on the tailgate. Someone need to photoshop that.
too late, im already mocking that up on my bronk. the witch is on a cliff side to with mordor in the back ground and goblins are near! oh and my girl is 3/4 naked...
Some progress is better than no progress.
- image.jpg (231.5 KiB) Viewed 1132 times
Nice, do you ever run into the dimple die bending the part with the holes so close together? Do you use a hole saw? On anything smaller than a 1.5" I have been using a punch. I have come to dislike hole saws lately, after I chunked one in the notcher. The last bumper I did, I plasma cut the notches. That is a whole thread on its own about notching.
Well when I dimple a piece and it turns it into a big curve-- I take the "female" part of the die and re-press the part flat again. It makes the part almost flat enough if not perfectly flat again.
Ya, I basically use a big moving blanket rolled up on big piece to soft bend it back to flat. Almost like a slip roller.
Add more pressure if it starts to taco. Mines a 20 ton press and I get 1/8th cr perfectly flat. Anything thicker my press is too weak for the desired effect. ( wont give full impression and tacos) I use a combo of hole saws, or greenlee knockouts. If I were rich n famous I'd buy the mittler bros set. The mittler set punches and flares via a bolt same as a greenlee knockout. Pretty bad ass but nearly 900$. They also have triangle and square punch flares.
Just use the female end and press it against a flat base after your done with the dimple, if that makes sense.
That's exactly what I did last night after that thing started cracking.cs_drums wrote:Just use the female end and press it against a flat base after your done with the dimple, if that makes sense.
Looking good Rob!
So I got that side pictured welded in last night, silicon bronze makes crappy beads I must say, but the door weatherstrip covers the weld thank God. Replacement carpet kit showed up yesterday also. Quality looks fairly decent, we'll see how it fits.
Good - I thought I was the only one. I guess not. That stuff just mushes around vs. laying down nice & flat like steel.Rmc wrote:...silicon bronze makes crappy beads I must say...
No your not alone. The beads can be somewhat decent but its far from a stack of dimes, more like a stack of lumps. But it dosnt look too bad if you wire brush it after. Hard to make it not lumpy though. Good thing is that you can come back n re-melt the high spots and you can't tell. In my case I was doing it vertically so it was even harder. Just seems the melt point is so low you work the previous bead when your a waise away from it.ChaseTruck754 wrote:Good - I thought I was the only one. I guess not. That stuff just mushes around vs. laying down nice & flat like steel.Rmc wrote:...silicon bronze makes crappy beads I must say...
Finally got both sides welded in. Threw some primer on em.
- image.jpg (222.02 KiB) Viewed 1001 times
Rob what about a long horizontal along the door sill??
I'm not really going to do anything with that yet, I'm going to do 2 hoops from side to side for the front seats to mount to once I get my seats.
So I got some neoprene today, was working on my rear shock boots. This will be my dust seal attempt below the carpet once finished.
- image.jpg (242.39 KiB) Viewed 945 times
