Wtb e4od transmission pan
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
Looking for a new pan with a drain plug oem or one that holds some extra fluid works as well. Figured I would try before either tapping the existing pan or buying a new one.
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Buy the dorman one. Its great quality and I haven't had one issue. Get the reusable gasket also.
biggiek
Re: Wtb e4od transmission pan
Post by biggiek »
I was going to go that way or spend the extra money on an additional capacity pan if I can find a deal.
I have a stock pan you can have. Just pay shipping.
birdco85
Post by birdco85 »
Will the stock e4od pan doesn't have a drain plug.
birdco85
Post by birdco85 »
There was supposed to be a comma in there. Lol
Will, the blah blah
Spend the money on the Mag Hytec and have fun with the 5 gallon fluid fills like me haha.
-shockseals.com
Protect those high dollar, high capacity trans pans as most are cast &will crack/shatter if hit with a rock. Stock pans will bend/deflect. Also - a drain is EASY to add on a stock pan - especially if you have it already off the truck. Buy a bung , drill a hole & weld it on.
