Starter
Re: Starter
I've got a couple here I think Travis. I know I have 1 for sure but can look a bit later for more. Do you know what spline count you need etc? I had one I had marked as 302 but can't remember if I sold it. The other one here I forgot to mark what it came off but I think it was out of a bronco as well. If you're up to a little size testing etc. shoot me a text when you're in the area & we can look through here & you can have what you want.
Re: Starter
All starters for Automatic 302/351W/351C are interchangeable. Only difference is tooth count on starter gear between some manual and auto transmissions.
We stole the 89 Mustang 302 manual starter off my 67 F100 with a 351C and put it on Jesse's 89 351W Bronco in Baja.
Re: Starter
That is what I thought, but wasn't positive.
There is a slight chance the 1 starter I have here for sure (haven't looked for others yet) may be ranger (would be off a 3.8L - which is probably the same as the 302/351 as well), or a 360 so that's why knowing spline count, or better yet taking this to a parts store & comparing all to a known, correct one may be smart.
