90+ Bronco
- Randyg12
- Bronco Info: I have a ford ranger, looking to upgrade to a bronco
90+ Bronco
Thought I would throw this up along with cruising Craigslist.
Looking for a 90+ Bronco. Preferably MAF (which is 95-96 if I'm correct) with the 5.8. Preferably stock or little done to it, as long as its not beat on.
Price range is ~5k. Low miles and cleanliness is a plus.
Thanks GFB!
Thanks GFB!
Re: 90+ Bronco
where are you located?
- Randyg12
Re: 90+ Bronco
Forgot that. I'm in Simi Valley CA
FUFIMI, I saw that one on Dez Rangers, smog equip isn't installed. I don't feel like throwing it on and possibly chasing a smog gripe, especially since they did a 5.0 to a 5.8 swap. Been there, don't like that.
- Randyg12
Re: 90+ Bronco
But thanks anyways, good looking out man!
- FUFIMI
Re: 90+ Bronco
Yea I wouldn't want to deal with the smog bs either. I will keep a look on Craigslist around my area for you and good luck on your search
- FUFIMI
Re: 90+ Bronco
How about this?
http://inlandempire.craigslist.org/cto/3838984513.html
Re: 90+ Bronco
That's mine. Lol.
Re: 90+ Bronco
this one looks pretty decent
http://www.autotrader.com/cars-for-sale ... x=16&Log=0
For sale is my PRISTINE 1996 Ford Bronco Eddie Bauer Edition fully loaded PRE-RUNNER with 142,xxx miles. Truck was used as a chase truck in the BAJA 500, NEVER RACED. This truck has the 351 Windsor 5.8-liter EFI engine, equipped with 4x4 on the floor with automatic locking hubs. LONG TRAVEL SUSPENSION with King 2.5 coil over shocks in front strapped at 13 of travel. King 2.0 smooth body shocks in rear with Pro Comp leaf springs with 15 of travel. Half engine cage and rear cage that support the shock hoops. King shocks, in the rear, travel through the floorboards for longer compression strokes that create extra travel. Custom front and rear PRE-RUNNER BUMPERS with front skid plate. 410 ratio Ford 9" rear end equipped with Posi-Traction, with support bars, and a high capacity MAG-HYTEC rear end pumpkin. REAR END was done at 122,058 miles. Transmission has a shift kit for quicker shifts. Front DRILLED BRAKE ROTORS suited for off-road and mountain driving. Rides on 33 BFG Baja T/A All Terrains with plenty of tread left on them. Oil was changed every 3,000 miles only using Valvoline High Mileage Full Synthetic. Recently repainted to SHOW QUALITY. PRESTINE INTERIOR with NO RIPS OR TEARS IN UPHOLSTERY. Alpine flip-up head unit with 7" screen that is Navigation and Bluetooth ready. Sick Stereo system with 4000w MA Audio HK series competition subwoofer Amp with two 12 MA Audio HK series competition Subwoofers. Alpine 4-channel speaker amp 1200w powering four Alpine Type-X component speakers. Two batteries, primary battery is an Optima Red Top battery located under hood and in the trunk is a DEKA Intimidator battery. Truck also has a Viper SST alarm equipped with remote start. HEADLIGHTS are HID 8000k. Truck has 2 Hella lights, mounted on front bumper. CA REGESTERED, with SMOG done on 2/25/13
$5975
$5975
Re: 90+ Bronco
that thing is sick! how many miles on it?Pushrod91 wrote:That's mine. Lol.
Re: 90+ Bronco
250 the od says. But the PO did a motor swap and no leaks and runs/shifts great.
