Threat ttb/Bronco cab and frame/motor and trans
Cant seem to find the time and money to finish my build. I have a complete front end, stock length threat billet c/t full plate and truss with uni ball ends. Brand new bearings,u joints,balll joints and brakes. Third member has 4.56, 6- 7/8 hiems with crossover steering, mile marker hubs. The links are not made just have the pitman arm and the swinger. Extra third member and spindles. The spindles that are on the kit are double sheered. Everything is brand new except the calipers and rotors. 3,700 firm for everything above.
I have a 94 Bronco cab and frame with a clean title. Interier is all their fuel tank and lines, front engine cage and trailer products hood and 2.5 flare on the fenders.No front seats 550.00
I have an 8.8 with 4.56 and posi. I have the kit to convert it to disc brakes, need to weld perches on the housing and then you can weld the disc brake adaptors on. 550.00
I have a motor and trans 5.8 with a e40d and transfer case. They came out of a rolled bronco that had 161,000 miles. Motor ran good with no leaks. Motor comes with doug thorly headers and msd billet distributor and msd off road box. Trans comes with a punisher valve body that is not installed. 900.00
I have a pair of prp extra wide seats with a drivers side slider and a passenger side tilt up.The seat are in good condition but they are blue and orange. 250.00
Call or text for pictures and questions, I dont visit the site very often Thanks Jeff
- Andy Jones
- Bronco Info: In the Works!
Re: Threat ttb/Bronco cab and frame/motor and trans
How do I contact you ?
Sorry no phone number..........951-306-8112
Forgot to include Threat boxed radius arms and 1 1/4 hiems also come with the frontend.
I think I need those deavers if you still have that other set.
Deavers are gone.
[img][img][/img][/img]
Sorry I need to start looking over what I post. 3,000 for the complete front end. 3,700 with the coilovers pictured.
1,000 for the 3.0 16" smooth bodys. Brand new never mounted.
700.00 for the 14" 2.5 coil overs, 350/500.
Coilovers sold.
Motor is sold. Trans is still available with transfer case 200.00, Threat front end minus the third member with gearing, I do have a stock one if needed 2500.00 for everything.
Pending sale on the steering. 2,000 for the beams, radius arms ,spindles, hubs ,brakes, steel braided lines, axles and stock third member, bearings, u joints, ball joints all new spicer stuff from Jeffs bronco grave yard.
I will seperate the steering if anyone is interested. I have two sets of drive lines also.
Beams and radius arms only 1700.
Price drop, 1400 for the beams and radius arms. 800 for the Fox 3.0 16" smooth bodys and 400 For the single swing steering with hiems no tie rods.
That's more than fair. It's way more than that to buy it from Dave at threat.BIGRED351 wrote:Beams and radius arms only 1700.
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
damn...tempted to pull out of savings and buy the beams/radius arms from you...subbed while I consider it.
