Looking to upgrade my 1990 Bronco and need some info/advice. It currently has a 4" Drop Beam lift quad shock front with a rear dif and leafs out of a similar year f250 and spacer blocks.
1. Would there be any benefit to running a longer radius arm with the stock beams and this lift? Looking to upgrade to CnT beams in the future.
2. Are those f250 leafs to stiff for a Bronco? Looking at Procomp 4" lift springs as better alternative and keeping $$ reasonable for me.
Thanks
E
Newbie Suspension questions
Droolsport
- Bronco Info: 1990 XLT with 351W 4" rancho lift
Re: Newbie Suspension questions
Yes, longer radius arms will be better than a stock radius arm & drop bracket, which I'm assuming is what is on there now.
For the F-250 leafs - do they feel stiff? The bronco rear ends are heavier than the trucks, BUT the F-250 springs may have been designed to have some weight in the bed. Either way the procomp springs are probably a better alternative as you'd get to ditch the blocks.
Just curious. The rear axle in your Bronco has 5 lugs, shouldn't it have 8 lugs if it out of a F250?
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
My .02,
If you’re going to go with a “lift kit” I would try to piece together a used one, plenty of guys on here have ran them temporarily and will likely sell at a fraction of the cost with minimal wear. You will want to go to a c&t very quickly, at least that was my experience.
As for the rear springs, I wouldn’t bother with anything other than deavers, again, people on here sometimes sell them cheap, I’ve bought two sets now for $300 & $350, I had deaver go through them for another $200 and now the rear of my truck is basically done.
I suggest throwing up a wanted ad for both of those things, and see what kind of feed back you get.
Droolsport
Thanks for the feedback. I was told the rear dif and springs were F250 and the dif cover matches 10.25 but it does have 5 lug axles?
Good idea on the want ad
Droolsport
After further review it is a 8.8 dif.
That makes more sense. Almost asked yesterday if you looked at that.
Not that it changes my opinion on anything I posted above, but are you sure the leafs are F-250 stuff?
