V drive?
wookiee156
- Bronco Info: 1988 full sise aka "The Blue Mare" soon to be prerunner / chaserig
V drive?
Hey guys I came across this gem on the Instagram thoughts??? I was not sure if this is the right spot for this so if it needs to be moved go ahead
- Anyone ever see/use one ?
- B01391CC-C616-4F60-8A1D-5AFA3FAE467F.png (564.06 KiB) Viewed 2625 times
Re: V drive?
These are what they did on some of the 4wd converted vans. I think I've seen them on both Chevy & Ford
Re: V drive?
An interesting system that was used on some vans, as ChaseTruck754 noted. It also was tested in a few cars.
And to keep it Bronco-related, this system was initially considered as the replacement for the solid axle Dana 44 in the Bronco before the Twin-Traction Beam was invented.
Todd Z.
Todd Z.
