4.88 and 35's?
95bronco12
Bronco Info: 1995 bronco 5.8 4inch lift on 33's
4.88 and 35's?
Post by 95bronco12 »
Hey guys, about to re gear my truck and needed some input. I'm thinking about putting 4.88 in the truck but I only run a 35 inch tire. For those who run that set up is it a good all around hear or should I run 4.56.
Re: 4.88 and 35's?
You should ask Birdco85. He has 4.88s.
Do it if you have overdrive. I have the same combo and love it.
4.88 and 35's?
^ I concur ^
damon1272
Re: 4.88 and 35's?
Post by damon1272 »
I run 4.56 with 35's and it works fine on the highway but 4.88 would work fine and probably work better with a load in the truck.
Mesozoic
Bronco Info: '79 Bronco: 408C-ZF5-NP205 SEFI-EDIS8; 4" lift, Dana 44/Ford 9" w/4.10s, locked
Re: 4.88 and 35's?
Post by Mesozoic »
I'm running 4.11s with 35" tires and like it fine, but I'm definitely looking for overdrive past 80 mph.
'79 Bronco: SEFI-EDIS8 8.5:1 400M-C6-NP205-Ford9-Dana44-4.11s locked, 35s, lifted 4"
birdco85
Bronco Info: 95 5.8 MAF E4OD
4.88 and 35's?
Post by birdco85 »
I'm happy with the gears. I did it with the assumption that some day I'll go to 37's and don't want to regear again. Very streetable and great off road.
DesolateMotorsports
Bronco Info: '92 with a slue of Desolate Motorsports products on it. Long travel, stock width
Re: 4.88 and 35's?
Post by DesolateMotorsports »
I have done both 4.56 and 4.88 with 35's. I like the 4.88's a little better (if your truck has OD) that extra couple hundred rpm's on the fwy is worth the low end torque you get. Especially with a stock motor
