The BroncO 'Bama Build
ThrustMaster
Bronco Info: 1985 Bronco Victorian 2 tone blue stock at the moment
Post by ThrustMaster »
I guess its time to start posting pictures of my 1985 Bronco XLT auto 5.8 build. Bought this last year and had to rebuild the engine becasue of cam bearing failure. The plan is to offsett the awful truck culture of Texas with something cool and functional. Just started building the eams this past weekend and got the new cam broken in. The plan is to finish the beams and mount with threat radius arms and run a 2.5 CO and 2.5 smoothy. Mount glass and then drive it for the summer. I will start working on the cage next winter.
bronco cross.JPG (197.45 KiB) Viewed 6347 times
extended beams.JPG (162.09 KiB) Viewed 6347 times
bronc engine.JPG (182.34 KiB) Viewed 6347 times
ThrustMaster
Re: The BroncO 'Bama Build
slowly but shurely getting the beams done
beams 2.JPG (93.2 KiB) Viewed 6253 times
mobil1syn
Post by mobil1syn »
buy a 55 gallon trash can, 5 gallon of simple green concentrate, dump simple green in trash can, fill with water, drop beam in and let it soak for a few days, flip it over, let it soak for a few more days, let it dry and cleaning whats left will be much easier. i usually do the trash can procedure and theyre clean enough the locate powder coat place will media blast em for me.
mobil1syn
Post by mobil1syn »
ooh and if youre going to run glass, you can wear socks with sandals dude
ThrustMaster
mobil1syn wrote:ooh and if youre going to run glass, you can wear socks with sandals dude
They are spark proof socks.
ThrustMaster
Weekend updates.
bronco inner fender.JPG (237.38 KiB) Viewed 6197 times
motorbreath53
Bronco Info: 96' 5.8, 4.88s, TracLoks, 35 km3s, Cut/Turns, Autofab Buckets, Rancho Arms. Daily Driver.
Post by motorbreath53 »
Cool stuff!
I want to widen a set of beams next time I have one apart. Seems straight forward enough.
Whats your plan for axles? And are you acounting for the lift with moving the balljoint or are you building it into the splice on the beams?
*96' Bronco 5.8, 35's Daily Driver
*94' F350 CC SRW 4x4 IDI Banks Turbo, ZF5, Warn Hubs 4.56s
and some other stuff that doesn't fit this forum at all...
ThrustMaster
motorbreath53 wrote:Cool stuff!
It's a lot of work and patience.
I built 2 degrees of camber into my extension plates, less than most turns but my pivot points are sightly lower. I am going to extend and sleeve my stock ones until i am sure that everything is the way i want it, then ill get some made.
ThrustMaster
Driver's side beam is done, finally...
Becks_Bronco
Post by Becks_Bronco »
Looking good man!
If you have not already bought the Threat stuff, you may want to look into Giant, Desolate, Solo, Oocho, Southwest etc. I have heard from a number of people that the fit/finish and fitment on the Threat stuff leaves something to be desired.
entity-unknown
Bronco Info: 87 Bronco 302 HO w/ MAF/AOD owned since 2001.
Post by entity-unknown »
While the others vendors may be prettier, it's cuz they have jigs and do it all day with a dedicated crew. You may not have the best welds but they're good enough for what you want. If you're gonna do cut&turn, you might want to practice a bit more for those life critical welds pie cut welds but your quality looks good enough as is. You saved yourself about a few thousand and no shipping BS -materials :)
Smooth Operator and good luck!
I believe Yikes said it best to me one time. I've had the prettiest welds break and the ugliest hold. It's all about penetration.
ThrustMaster
Got the beams mocked up and working on radius arm mount locations. I had to cut off the old side pipe mufflers, won't miss those.
Looking good
ThrustMaster
Got the beams on and did some cycling. pretty happy with the bump travel so far.
looks good
ThrustMaster
Had to rear work the shock mount a bit, but am happy with it now. The damn master cylinder is right where i want to put my upper mounts.
I know the feeling. I am working out the same issue myself. I'm thinking a bend near the master cylinder to clear it. It's either that or go hydroboost.
ThrustMaster
made more progress, finished up the drivers side. on to the passengers side.
Becks_Bronco
looking good!! It took me as long to install a set of manual hubs as it did for you to mount the front suspension. I'm envious of your progress lol!
