Anyways, I'll chronicle the progress of working on my 96. I'm not looking to build a ultimate hardcore truck but something that is a good all around performer.
A bit of history:
Was given the truck as a HS graduation gift in January of 2000. Had 83K on it. Took me through college and the first year of work. I grenaded a driveshaft at 70 on the freeway and took the t-case adapter with it in October 07. Parked it and bought a 06 Charger R/T (love that car too) Finally got around to fixing he truck in January 08 then decided in April at 197K to pull the motor to do add some more go.
Some pics:
I started at a bit different point than most in that I wanted to build the engine first (what can I say, I like horsepower
List of stuff done in the motor rebuild (initially):
smooth block casting inside and out
chamfer oil drain holes in block
check deck, crank and cam bores (all perfect)
hone cylinders (stock bore)
all new bearings and plugs
smooth crank and rods
balance rotating assembly (stock hyper pistons)
World Roush 200 iron heads (64cc chamber, 2.02 and 1.6 valves)
Edelbrock Performer Truck intake
BBK 61mm TB
crane cams 444211 cam
crane 1.6 roller rockers
comp cams pushrods
Milodon windage tray
ARP oil pump drive
MSD billet distributor
MSD coil
Taylor spiro pro wires
bassani headers, y-pipe and magnaflow muffler
some ford racing valve covers to top it off
various ARP bolts and such for various things
autofab motor mounts
The milodon windage tray and where it needed to be cut to work with the stock oil pickup
All put together
getting ready to go in
in the truck
soon after it was running (the squealing was a bent crank pulley corrected by a aluminum march power& set)
http://www.youtube.com/watch#!v=a8Ay8K3 ... re=channel
well got it all in and proceeded to put 5K miles on it. truck did great. Then a valvespring popped and droppd a exhaust valve in #5. I'm not sure if it was a spring failure(bought the heads used with supposedly only 3K miles) or if the heads were equipped with less than required valves, but what happened happened. Goes to show do not take anything for granted.
oops
So I decided to go ahead and get some proper aluminum heads and a bit healthier cam
Enter some AFR 185's with 58cc chambers and a trick flow stage 1 cam along with some ARP head studs. Talked to my machinist and showed him the pics and he said since it only nicked up the piston smoothing it out should be no issue and it wasn't.
Going back together
It's definitely got a healthy lope to it now
http://www.youtube.com/watch#!v=AxzRUWE ... re=channel
(for some reason the camera really seems to pick out the valves and makes them seem way way louder than they are)
Truck runs well overall, no torque hole down low like other people preach that anything more aggressive than a stock cam will have
That's where it stands currently, I'll be updating as everything progresses
