Mark's Arizona Bronco
nosamax4444
Bronco Info: 1989 Bronco XLT 5.8
Post by nosamax4444 »
Hey All,
I got my Bronco Aug 2013 with the intention to use it as a hunting/shooting truck and to take my kids offroad. Well similar to many of you guys, my passion for the truck has progressed much further than i would have expected. It started with simple coil spacer, then by dec 2013 quickly progressed to cut and turn beams (the right way :D ) and procomp springs with plated rancho radius arms and custom shock mount for 10" 2.0 fox shocks. For the rear to got a custom 10pack deaver setup from a guy on craigslist that had it on a 91 f150 he raced in short track. Perfect spring rate and stockish ride height. but droops like no other with a fox 2.0x12.
Cut and turn the right way + clock diff = happy ball joints
I wheeled her like this for 6-7 trips in march-may 2014 then under the knife again during the summer.... This time roll cage and coilovers. I spent lots of time on this site checking out everyone's setup and saved photos of the stuff i liked. I ended up taking the truck to a buddy of mine's fab shop to have him fab up the things i wanted done. I am very inexperienced with a welder and he is a master at tig welding and also very well priced so i left my truck with him for the past 4 months. I got the truck back last week and am super excited. like i said i went a little overboard. Ended up with 2.5x12 king tripple bypasses in the rear and 2.5x12 king coilovers in the front
full droop mockup
rear travel
full droop mockup 2
1.25" Heimed radius arm in progress
coilover mounts are beautifully done.... I was most pleased with this
all finished with fox 2.0 bump
Rear setup
some travel pics (not fully drooped out)
I also got suspension seats built into the cage, i'll take pics soon and am working on tying up loose ends (vacuum canister relocate, new over flow reservoir (stock one is ugly), etc. I did take her out this past weekend and she feels great. Just a quick shake down, no jumping yet until i get everything sorted but I am super excited. I bought almost everything on craigslist and did this build relatively cheap (believe it or not).... I am very thankful for this site, as I have learned almost everything about how to modify broncos on here. Feel free to ask any questions. In the mean time, i am hunting for used 35s and a place that will regear my diffs for a good price. Also have to do bumpers and tire carriers.... the list keeps growing. :lol:
Thanks,
Mark
nosamax4444
Re: Mark's Arizona Bronco
for some reason this picture didn't post
Couldn't see any of the pics. Sounds like a cool build.
nosamax4444
Tanner287
Post by Tanner287 »
It sounds pretty sweet I wanna see pictures, using photobucket is really simple to upload pictures on here. Make an account, then upload the pics to photobucket, then press the "copy" and then you copy the img link and post in on here
nosamax4444
2nd try with photobucket :)
full droop mockup
rear travel
full droop mockup 2
Rear setup
Thanks,
Mark
Sounds nice! Im in mesa.
nosamax4444
awesome. Are there ever any AZ meetups? If not, we should.
Im going to the sand drags tonight in AJ at ET Motopark if you want to come.
About your "pie-cut" cut & turn-- now I have only done the C&T process once and it was the pull the bottom out. With that said I wouldn't do it again. I have seen a couple of really good fab guys do it that way and to me there is just way too many possibilities for error where with the Pie-cut method there almost can't be an issue with getting anything crooked or not in place properly. I guess you need some very mild clocking-- one idea I had was to take a solid axle Dana 44 diff cover place it where the third member would bolt up, tack weld it in place 3 or 4 spots, take a brand new cobalt bit and redrill the holes. Seems to me to be a almost no-brainer and virtually zero fail.
Nice work so far-- I wish I was in AZ now to see your truck!
nosamax4444
vintageironfab - Im actually a big fan of your build and got lots of inspiration when doing mine. Did you move out of az?
Ryan - im in the northwest valley, aj is like 1hr+ from me. Maybe another time with better planning.
Thanks Mark--I was inspired by the Yikes build :-). The only thing I did that others may not is just put a crazy high effort into cleaning every inch of the chassis and drivetrain to the point of insanity :-). Well I moved sorta to North Dakota to get a piece of the oil boom going on out here (which has financially be very good) but all my stuff is still in AZ awaiting my full time return in 2 years, 159 days and 11 hours .. Lol :-)
If cutting and turning the entire knuckle mount to keep the ball joints in alignment is best, why don't people incorporate the difference into the portion they use to extend their beams? Seems like cutting some C shaped steel a and angle shouldn't add too much difficulty to the process.
I think there are a couple guys who build a decent amount of beams do have a pair of proper sized channel bent professionally then cut to length with a horizontal bandsaw
If you're out there guys, let me know.
