95 bronco
Prerunbronc
Bronco Info: 95 bronco 5.8 coilovers, deavers, 2.5 fox, full glass, air bumps, 9" rearend
95 bronco
Post by Prerunbronc »
Here is my bronco when I got it. I was not looking for a show truck mostly for a solid cab and drive train
I then added front and rear fiberglass changed the hood , doors, and grill so it didn't look like such a piece in front of my house
Prerunbronc
Re: 95 bronco
I then cut and turned my beams and made radius arms
Prerunbronc
Re: 95 bronco
I plated the radius arms befor installing next was to mount the coilovers and air bumps
I didn't get I final pics of the install but you get the idea
Prerunbronc
Re: 95 bronco
Now it is time for the rear f53 and 12" x 2.5" fox
I then regard the front and rear to 4.56 and added an auburn LSD to the rear and added 5/8 wheel studs front and rear
Prerunbronc
Re: 95 bronco
Next it needed a rear bumper
Prerunbronc
Re: 95 bronco
Front bumper
Prerunbronc
Re: 95 bronco
New beams I made 4" wider
When I install them I am going to redo the engine cage and run 14" 2.5 fox coil over I have also redone the rear shock mount.
I am building a 9" for it right now but have a few projects going on so who knows how long till it is in
Prerunbronc
Re: 95 bronco
Re: 95 bronco
Looks good! I like what you have done with it so far!
argonaut
Bronco Info: 96 Bronco XLT Supercharged
Re: 95 bronco
Post by argonaut »
Looking good. Seeing yours is almost like looking into my future!
Maybe I'll take that rear end off your hands someday when you finish building the 9".
Jason M.
Re: 95 bronco
Post by shockseals.com »
You still running the 10" DL coilovers?
Prerunbronc
Re: 95 bronco
I still have the 10" DLs on there for now I have been looking for some 12s or 14s for it for when I swap beams.
