Roots 93 Bronco
805BroncoAZ
Bronco Info: 1993 Ford Bronco
Roots 93 Bronco
Post by 805BroncoAZ »
Hey,
Newer to the forums and been lurking around checking out different builds. I purchased this Bronco awhile back, and have some future plans, but for now working on making it more comfortable.
Current specs
1993 Ford Bronco
Engine
351
MAF Conversion
Mild cam
Edelbrock Intake
Bassani Exhaust
Front suspension
Cut and turned beams done by Threat
2.5 Sway Away Coilovers
2.0 bumps
Custom swing steering
Rear suspension
Q80 leaf pack
Threat shackles
2.5 King smooth bodies
Trussed 8.8
4.56 gears front and back
33 inch BFG AT
Caged front to back
Recent mods
Installed a Lowrance GPS
Installed Rugged Radios race radio and intercom
Currently in the process of stripping the black spray paint off of the wheels to see what the finish is under. I really like the raw aluminum look on these trucks so hopefully the finish is okay.
There is some spots through the firewall that needs to be sealed to get it dust proof. I have Killmat to install once that’s done.
I also have a full custom air condition kit I am prepping to install. It has two units, one behind the dash, and another unit that ties in, so I can mount it on the cab cage for the back seat area. Similar kit they use in the H2 I believe, anyways here are the pictures and I will update when I have progress! Image
Re: Roots 93 Bronco
Great start. I dig the dash.
Pickuptrucker
Re: Roots 93 Bronco
Post by Pickuptrucker »
rad
