My 95
Tanner287
My 95
Post by Tanner287 »
Even with the awesome heat we had this weekend I wanted to get the truck done. It’s back on the ground and all good! I made the first set of tie rods out of .120 wall with weld in bungs but the final ones are tapped .313 4130. Pretty stoked on how everything came out.
My 95
Tanner287 wrote:Even with the awesome heat we had this weekend I wanted to get the truck done. It’s back on the ground and all good! I made the first set of tie rods out of .120 wall with weld in bungs but the final ones are tapped .313 4130. Pretty stoked on how everything came out.
So rad !
Pumped for ya, man !
Tanner287
My 95
Post by Tanner287 »
Pismo was a blast, but I broke my bedcage on the last day. Decided to cut it all off and start fresh. Was able to push the shocks out on the axle a little further and do some other stuff like downsize the bump stop pad and give me a whopping 1/2” more of up travel. And made some new bushings for the leafs. Bassicslly everything on the rear suspension is new
Re: My 95
Nice! Who made that 1st shock hoop/bar? And assuming you made all the replacement stuff?
Tanner287
Re: My 95
Post by Tanner287 »
The first one was solos, but I know they have since changed their design to be stronger. And yeah I made all the new stuff.
Re: My 95
Got part #s on the new spring bushings?
Tanner287
My 95
Post by Tanner287 »
dtbback wrote:Got part #s on the new spring bushings?
Yeah it’s tanner287164819
Lol I made them myself I’m not aware of anyone selling them.
Re: My 95
If you made them assuming you did them out of delrin?
Re: My 95
Autofab sells them, if you don't mind red.
Tanner287
Re: My 95
Post by Tanner287 »
ChaseTruck754 wrote:If you made them assuming you did them out of delrin?
Yes I did make them out of delrin, don’t have much driving time on them and maybe it’s my imagination but I feel like it tightened everything up. Felt like less body roll I liked it
Tanner287
Re: My 95
Post by Tanner287 »
Well that’s cool I did Not know that! I had this delrin leftover from something else so these were free99, my favorite price
Re: My 95
They should tighten everything up nicely. The poly allows a bit of flex or roll side to side on the leafs where the delrin does not. I have delrin ones I made years ago in my crew, but I never finished the thing so as to drive it & see how they felt :(
Tanner287
Re: My 95
Post by Tanner287 »
I was hoping it would! Especially for jump champs I can use less body roll.
Tanner287
Re: My 95
Post by Tanner287 »
Okay so currently I have a 351 that’s stock other than the edelbrock upper and lower intake, exhaust, and I had a custom tune put on the truck. It’s only putting down 170 to the wheels right now.
I was going to do a LS swap but now I’m thinking I’m going to link it next summer instead. Anyways to my question haha I want to squeeze out a little more hp
What aluminum heads and cam should I run, larger injectors and throttle body? After I do heads and cam is my stock trans going to hang in there? What kind of gains could I expect with heads cam injectors and a larger throttle body? I don’t want to throw money at it for nothing
Re: My 95
Tanner287 wrote:Okay so currently I have a 351 that’s stock other than the edelbrock upper and lower intake, exhaust, and I had a custom tune put on the truck. It’s only putting down 170 to the wheels right now.
I think Kritters 408 build wouls be a great one to copy. Especially, if you're just doing a top end upgrade.
Re: My 95
Problem with that is a 408 isn’t just a top end. Very first question is simply does it need to be smogable?? I personally would never use an AFR 165 head when a 195 is so much better for a 351 for the same money. If no smog the intake manifold choices are pretty wide that flow better than the stock upper.
Tanner287
My 95
Post by Tanner287 »
Suggestions on which electric out of tank pump and regulator to use with my 351? Getting a fuel cell soon so I need to figure it out
alpinejd3
Re: My 95
Post by alpinejd3 »
Tanner287 wrote:Suggestions on which electric out of tank pump and regulator to use with my 351? Getting a fuel cell soon so I need to figure it out
I have had good luck with AEM and Aeromotive pumps, currently have the AEMs on the bronco. Phoenix regulator has done me well too.
Tanner287
My 95
Post by Tanner287 »
I was recommended this pump
https://www.summitracing.com/parts/bch-61944
And told I do not need a regulator than the stock one will be fine
Tanner287
My 95
Post by Tanner287 »
So I bought this running 5.8 lightning motor out of a 95 f150, i dont know why I bought it yet but it was cheap so I just did it haha. I already have the Edelbrock intake on my motor, I really was after the gt40 heads but now I like the lightning intake it’s pretty cool.
Any idea what would perform better the lightning intake or the Edelbrock?
This motor was speed density I have maf on my bronco now. If I decide to just drop this motor in my truck can my harness just plug and play?
My options are either cam the lightning motor and drop it in
Take the heads and put them and a cam in my motor.
