Dusty Bronco
Dusty Bronco
Bronco looks great. Jealous!
- cwrisley
Dusty Bronco
Made a day trip down to the Arroyo Tampiado mud caves with fam. Weather was perfect and the Bronco did great. 202 miles round trip, and she kept purring the whole time. This thing keeps impressing me everytime we go out.
- cwrisley
Dusty Bronco
Running open diff on stock gears is fun, but not that fun. Time for an upgrade.
The pile is getting bigger...
Dusty Bronco
cwrisley wrote:Running open diff on stock gears is fun, but not that fun. Time for an upgrade.
Nice upgrades !! Rear Locker and gears are a must man. That's adventure looked like a good time.
Dusty Bronco
Wow that cleaned up fast!
- cwrisley
Re: Dusty Bronco
My OCD kicked in. HahaTchajagos wrote:Wow that cleaned up fast!
- cwrisley
Dusty Bronco
Finally did the 3G 130a amp upgrade. Woke up to a dead battery and an even deader alternator. (Deader? Seriously?) New Die Hard (Dekka) battery and reman alt from Napa. PN was for a 94 Mustang. Wiring upgrade was super simple thanks to a diagram I found posted by Philo. Helped a lot. While I was in there, new starter and new 1/0 battery cables on both sides. Ordered them from custombatterycables.com. They have ready to go sets for Bronco/F150s. Highly recommend. Everything went together smoothly. Birdco came by and made some 6g alternator cables for the solenoid and breaker.
Started the "Sixlitre tuneup". Cap, rotor, 9mm Ford wired, MSD Street Fire coil. Just need to gap the plugs and advance the timing
As mentioned in the tech thread, new steering wheel is in....
New heater core is next up on the neverending list.
- cwrisley
Dusty Bronco
I went to the junkyard last week searching for derby car parts and stumbled upon an '04 Expedition and the center console was still in it. They wanted half of what eBay is asking so I jumped on it. Using the factory mounts made this an "easy" install. Race radio will be mounted in the cubby along with the switch panel for lights and fans.
Sent from my SM-G928V using Tapatalk
Re: Dusty Bronco
Almost looks like it was meant to go there - nice score.
Re: Dusty Bronco
Wheel looks good wish I could ind a CC adapter so I could justify replacing my worn out OEM one.
- cwrisley
Dusty Bronco
I started to get a nasty shake when turning. Sector shaft had some play, so time for a steering box. I looked into my options (Redhead, PSS, etc) and wanted to keep it "desert repairable". I ended up doing a Napa "4 bolt" 1 ton steering box swap. The box is for an Excursion (PN PS39-1018). It has a 32 spine shaft so the Bronco pitman arm still works. I got the pressure line for the Excursion (PN NPS7-3506) and all the fittings work. I tested them on a stock Bronco pump before I left Napa. No leaks so far and steering feels tighter. I also swapped out the drop pitman arm for a stock since I don't have drop brackets. Time for an alignment....
Dusty Bronco
100% bolt on? What beefier about it?
- cwrisley
Re: Dusty Bronco
Yes, the casting is identical so it bolts right up. From the info I gathered, the gears are larger and have been known to last longer than the 2 bolt. I don't have any experience with that other than my 2 bolt just took a shit at 160k miles. It also has a slightly tighter turn ratio than the 2 bolt at 4 turns lock to lock.cs_drums wrote:100% bolt on? What beefier about it?
Re: Dusty Bronco
Does it have a faster ratio or the same battle ship steering response that the bronco s have always had?
- cwrisley
Re: Dusty Bronco
Its got 1/16 less turn, so not too much faster. But the slop is gone and just "feels better". Once I get the alignment done I'm sure I'll really notice a difference. Since switching back to a stock pitman arm, Ive got a lot of camber and the front end is riding high.damon1272 wrote:Does it have a faster ratio or the same battle ship steering response that the bronco s have always had?
I read that the 03-08 Dodge 1 ton steering boxes are also identical, yet have 3 turns lock-to-lock. Might be worth looking into. Fitting sizes will be different I'm sure.
https://www.napaonline.com/en/p/PNB391065
@cwriz
Re: Dusty Bronco
Cool Good to know. Thanks
- cwrisley
Dusty Bronco
Got the headers on with some help from Darren birdco85. Summit Pacesetters. I know they're not Bassani, but I'm a baller on a budget! I used the Stage 8 fasteners, so hopefully no leaks. I've heard good things. Snagged a Saginaw pump for a core and bracket from the junkyard and made the swap. Should help push this 1 ton steering box around. Gonna add a cooler I've got. With the headers, came a smog delete. No more cats or EGR. I'm lucky enough to be registered in a smog exempt zip. Buzzed on a collector I picked up off eBay which worked out much better than I thought it would. Gonna add a Magnaflow glasspack, because I like loud noises.....
That is all for now.
- cwrisley
Dusty Bronco
Heat exchanger replaced the old factory hard line. Power Steering is finally done.
- cwrisley
Dusty Bronco
I don't see what the big deal is....
Re: Dusty Bronco
Holy crap! Never seen that before!!
