Another Bronco Build
- ChiroMatt
Re: Another Bronco Build
That potential for strap pinching or bracket
Frame contact worries me too.
Will try your bungee idea, thanks.
Run it and see what happens!!
- ChiroMatt
Front tube structure in today.
Used the autofab "kit".
Pics are of it tacked in,will post fully welded
Pics later. Pulled a 12 hr day and forgot
To snap the finished installed product.
Bolt in to radiator support and cab so it can
Be removed.
What do u all think?
Be removed.
- image.jpg (188.61 KiB) Viewed 1024 times
- image.jpg (190.07 KiB) Viewed 1024 times
- image.jpg (152.8 KiB) Viewed 1024 times
- image.jpg (184.24 KiB) Viewed 1024 times
- image.jpg (250.05 KiB) Viewed 1024 times
- image.jpg (197.66 KiB) Viewed 1024 times
- ChiroMatt
She is a roller after 4 months!
Again a massive 12 hour work session
Today.
Brakes r bleed
Power steering fluid in
HID lights are in
Glass is hung
Hood pins in
All tabs for remounting
Started engine after 4 months started right
Up with out hesitation.
Issues
Leaf spring shackles are hitting the under
Body support area, trimming required or
Hammering.
Hid main lights don't come on, everything
Other light works, probably wired wrong.
Pics
Today.
Brakes r bleed
HID lights are in
Glass is hung
Hood pins in
Issues
Hammering.
Pics
- image.jpg (191.92 KiB) Viewed 942 times
- image.jpg (189.72 KiB) Viewed 942 times
- image.jpg (199.48 KiB) Viewed 942 times
- image.jpg (183.6 KiB) Viewed 942 times
- image.jpg (178.68 KiB) Viewed 942 times
- image.jpg (192.1 KiB) Viewed 942 times
That thing is looking great !
- ChiroMatt
Thx RMC
been dreaming of my own prerunner bronco for a long time.
Lookin great!!
With HIDs you may have to repin the connectors...I had to try a few different configurations before mine worked correctly
- ChiroMatt
Thanks Tony
Robertcrav, rechecked all my wiring and found
A few installer errors!
Forgot to ground the drivers side. And
The positive was not getting a good electrical
Connection. Fixed these two things and the Baja HIDs
Work perfect.
The Baja HID system came 100% ready to plug and play
And works great, very bright, wish the same could be said for the
Installer!!
Work perfect.
Installer!!
- fomoco51
Very nice. You kicked ass on this thing. Now go have fun. Hoping to have mine out of the garage by sunday. So I can do a 3 day shake down before huckfest.
- ChiroMatt
Fomoco,
Thx, major progress in September, think this Sunday
Will be the final fab day b4 shake down.
Still lots to do, but it will be drivable and let the
Fun begin!
Fun begin!
- ChiroMatt
Ran into some shackle on body contact, blow torch
Hammer, cutting wheel time, will reinforce this weekend.
Any one else have this issue??!
- image.jpg (158.75 KiB) Viewed 790 times
- image.jpg (183.81 KiB) Viewed 790 times
- image.jpg (170.68 KiB) Viewed 790 times
Matt -
Cut this part out of the fender, it will fit better
![Image](http://i31.photobucket.com/albums/c354/Travisfab/Untitled_zps44c138fc.jpg)
It's actually there for guys that are not running the core support
Shackle issue is common when using F-150, ranger or other shackles. Broncos have more body "meat" there & hit as you can see with the 7.5" shackles. I think I remember 6.5" being as long as you can go with no contact there.
Be sure to reinforce what you cut out well. That is a pretty good support for the body & it will start cracking & pulling apart back there if a bunch of the structure is left out.
Yes, it's + 1 inch over stock that is about the max. It still leaves .200 or so but I'd be worried if urethane is being used as I would imagine the squish factor would allow contact.
That being said that's basically why solo makes the rear hanger drop kit. It supports the longer shackle while still allowing clearance.
- ChiroMatt
chasetruck and rmc,
so many little details with these broncos... its all new to me. I gleaned what I could in advance of build for GFB
and during, but I missed this details!!.
Will do on the reinforcement.
Thanks
Thanks
Feel free to ask questions matt, lots of peeps on this site have been there done that and asking may save youa bit of extra work. I personally was going to do the exact same thing you did but was forewarned by another member. I'm glad to see others help me so in turn I'm more than happy to help others. Keep up the progress it's looking good.
- ChiroMatt
Thx rmc will do.
- ChiroMatt
Somehow I missed that the rear shackle
Hanger had to be lowered or get an after
Market one...,
I will reinforce the areas that got cut out.
Market one...,
- Passenger side trim looks good
- image.jpg (150.13 KiB) Viewed 652 times
- Here is the drivers side clearly needing more trimming
- image.jpg (258.35 KiB) Viewed 652 times
- ChiroMatt
Baja HIDs look great
Great customer service
Best of any of the parts vendors
Thx Tony
Oh, these are the 55w ones!
Thx Tony
- image.jpg (155.61 KiB) Viewed 645 times
- image.jpg (237.07 KiB) Viewed 645 times
- ChiroMatt
Leveling the bronco
Put an inch of preload in the front
Looks front end high
But the
Level says level
Preloaded the rear with a few hundred lbs too
But the
Level says level
- image.jpg (188.55 KiB) Viewed 643 times
- image.jpg (192.84 KiB) Viewed 643 times
