What I am looking for, is a box with hydraulic assist without catch at low RPM. I had already modified my system with an AGR ram and a high flow pump to only have the system catch at a wrong time. I was drifting in the woods when I had to quickly counter steer and wasn’t able to do so because of the speed of the RAM. The Bronco ended upside down after flying over 3 feet bolder. (Great to have a cage!) Bad RAM assist experience! I have removed the system since then.
This is why I am now turning myself to big companies like Howe or LEE to see if they have solved these issues?
cdn bronco solid axle prerunner
cdnbronco
- Bronco Info: 1978 bronco, 3 link front, 4 link rear, fully caged, 460 engine, custom fiberglass,
Re: cdn bronco solid axle prerunner
Redid the wiring for the new mod. Going with the FAST 2.0 system on the 460. Still the old motor but should be upgrading the motor when the AFR 460 heads come out!
- IMG_2521.JPG (103.43 KiB) Viewed 694 times
- IMG_2517.JPG (134.52 KiB) Viewed 694 times
- ChiroMatt
Clean wiring!
I have a psc system, occasionally catches but
Cannot reproduce predictably, only notice
At slow speeds and again it's rare in occurrence.
Overall it's smooth as butter like a 70's caddy and if any complaints
It's over boosted, again like a 70's caddy.
