Zach's 94 Build
- johncharlesb
Re: Zach's 94 Build
Bad battery or drain.
Disconnect the battery and let it sit for three days and see if it holds a charge.
Check for shorts off the positive lead. See how much power the stereo drains while the truck is off. If the truck drains a 60a/h battery in 72 hours that is a .8 amp draw if you took that battery down to nothing or .4amp if you took it down to half of its total. That is only five/ten watts. You can measure for drain and start pulling and replacing fuses until you located the bad circuit. A relay sticking, bad diode in the alternator?, fuel pump relay, etc.
My guess is a bad diode in the alternator. See if it is warm when the engine is cold, try disconnecting it and measuring the power consumption.
Batt Issues
Thanks for the advice guys.
Took a few hours this morning and tore into the battery issue. I found a intermittently sticking relay in my amp box behind the front seats. It would draw .28 - .34 when connected and .03 - .05 when it wasn't. Once I swapped it for a tested and known good relay, I could not get a reading of over .05 on the meter. I'm hoping thats the only issue that was going on. If not, I know that one part of the equation has been solved.
Fingers crossed.
Fingers crossed.
Re: Zach's 94 Build
Good luck buddy! It sounds like you have found most of the issue.
- SuperSixAxis
- Bronco Info: 1996 5.8, E4OD
Re: Zach's 94 Build
Crazy how a relay can hang up a build this nice. One of the nicest engine bays I have ever seen!
Re: Zach's 94 Build
Hahah. Thanks man. Now that I'm working through the gremlins, hopefully the rest of the truck will be as nice. Fingers crossed.
Re: Zach's 94 Build
Purchased a tweecer r/t locally and have been trying to get the motor and tranny dialed in and meshing. Such a crazy, amazing tool. Being able to datalog what happens under acceleration makes tweaking and troubleshooting infinitely easier.
Dropped off my Foreman coil buckets to be sandblasted and powdercoated. Ive been looking around and cant find a definitive answer as to what type of 4" coils to use. I've seen rancho and pro-comp listed a bunch. What does autofab/camburg package with there kits?
Also curious if there is a Bilstein dealer on here. Contemplating selling my 2.5x10 saws for a set of 9100's. Currently I'm running 7100's in the rear and Ive been really happy with them. Would love to have Bilstein on all 4 corners.
Re: Zach's 94 Build
Autofab was having theirs custom wound. When they ran out, John suggested i use a 4" skyjacker. The burglers were using a 4" procomp.Drilim wrote:. Ive been looking around and cant find a definitive answer as to what type of 4" coils to use. I've seen rancho and pro-comp listed a bunch. What does autofab/camburg package with there kits?
- Polarcub
Re: Zach's 94 Build
Contact Joel he goes by random thoughts racing on the board here...or you can PM me and I can help you out through another dealer.Drilim wrote:Purchased a tweecer r/t locally and have been trying to get the motor and tranny dialed in and meshing. Such a crazy, amazing tool. Being able to datalog what happens under acceleration makes tweaking and troubleshooting infinitely easier.
Jeremy
- economig
Zach's 94 Build
Glad this build is posting and moving forward again! Pics!!!
No pressure
No pressure
Re: Zach's 94 Build
I ran a 4" Skyjacker for a long time and it worked well and lasted.
Re: Zach's 94 Build
4" Pro Comp coil for about 9 months, paired with dual Bilsteins 5100s and they rocked.. it worked great.
Pulled my truck into my new shop space thursday evening and finally started tearing down the front end. Installing the Foreman coil buckets i bought from "Shockseals" on here, a set of 2.5x10" SAW's, a new pair of 4" pro-comp coil springs, and some other minor general front end maintenance/cleaning/painting/misc.
Ill get pictures up of the progress once I get everything test fit before it gets assembled.
I do have a quick question though...
I picked up a set of lower coil retainers from someone on here a while back. They had been milled down to eliminate the sway bar bracket. They look similar but arent the same as what I pulled off.
The coil spring seems to sit in the pad with the notch, just wondering if there is any reason i shouldn't run these. If not, Where can i find a set of coil pads that arent trashed like the ones i pulled off?
Re: Zach's 94 Build
Those are just spring pockets from an earlier truck/Bronco that had a different sway bar mount. Either set will work fine.
Re: Zach's 94 Build
I'm pretty sure there were different height coil pads/retainers over the years. I have a bunch of different ones here. If you want to email me with the heights of what came off I can see if I have the same ones. I can let um go for a couple bucks plus shipping. For a few more bucks I can cut off the sway bar mounts & sand smooth.
*edit* - I guess Philo beat me to it.
Philo - aren't there different height spacers out there though? I swear I have 2-3 different sizes here on the shelf. I know there is a height difference side to side, but I could have sworn there were a couple sizes of each.
Re: Zach's 94 Build
I think you got those from me Zach. I ran them with my Rancho coils.
Re: Zach's 94 Build
Left and Right sides are different heights as well as different models. F150/F250/F350 and Broncos all used the same basic lower spring retainer.
Re: Zach's 94 Build
Yikes, I did get them from you - forever ago. Lol
Philo, thanks for the info. They looked similar enough and seemed to fit fine but with my luck, id get it all together and it would be a major issue.
Re: Zach's 94 Build
Drilim wrote:Yikes, I did get them from you - forever ago. Lol
I drove my truck around for 6 months with the left and right swapped. It leaned a little to one side but other than that it did not create any issues. I don't even bother to run the isolator. Can't hear that noise over everything else.
Re: Zach's 94 Build
Ended up pulling the rad arms and mounts and having them re-powdercoated.
Picked everything up friday morning and knocked out remounting and getting the coils in and everything torqued to spec yesterday afternoon. The stance with a new set of pro-comp 4" coils is exactly what I was hoping for.
Didnt get the SAW's in, going to have them gone through before the go in. Threw a set of old ranchos in to have it aligned.
Phone was dead by the time I wrapped up. Ill get pictures up this week.
Re: Zach's 94 Build
After the debacle I've had trying to speak to anyone competent to help track down the SAW's i had...I placed my order with Joel@Bilstein today for a set of 9100 smoothbodies with the ACV upgrade in a 2.65X10. To say I'm excited is an understatement.
Joel was great. Called me and answered every question I had, explained it in idiot proof terms, and was very patient with me and my ignorance. Hoping to see them before Thanksgiving!
Pics to follow soon.
