94 Raptor killer
94 Raptor killer
I'm sure someone will argue why it's bad but has worked for me.
Re: 94 Raptor killer
If he's going to drill and relocate the spring locating pin he will need a cobalt drill or harder. Spring steel is tough stuff. Carbide would be best but cannot be done with a hand drill. The drill will chatter chip and break, carbide is harder than a whores heart but brittle to shock. Cobalt is the most cost effective drill that will accomplish the goal.
94 Raptor killer
I think he's meaning he drilled the actual perches welded to the axle.
Oh I thought he drilled the locating pin in the leafs.
Also above when I say by hand above I mean without the aid of at least a drill press.
94 Raptor killer
Yeah i used ruff stuff perches and drilled the leaf pin hold just under 2" back
Good call lol a heck of a lot easier than drilling leafs
Screw drilling leaves-- just use a carbide cutter on a die grinder if you ever need to open up a leaf spring hole. Drilling them is possible but only with a DP and a colbalt bit-- it's a nightmare though.
My thoughts exactly.
94 Raptor killer
So I finally got around to installing the econoline Saginaw. Are you guys that have done it making a new high pressure line or utilizing the econoline one?
94 Raptor killer
Maybe I should have looked at it before I asked haha. Van line worked great. I'll tell you have the core support pop out of the way makes working on the engine so much easier.
94 Raptor killer
As much as I wanted to replace the pump, lines and box with all new, not in the budget. Hopefully it all work for a few trips haha
94 Raptor killer
Little bit of wiring left and the front is done.
94 Raptor killer
Wired and plumbed. Getting close to done again.
Looks bad ass man. I really like the tube core support.
Looks bad ass. I'm really liking the tube core support
94 Raptor killer
No more A/C....
Plenty of room for the smog stuff though
94 Raptor killer
Thanks Robert. I always planned on it. It's funny thinking about a project is always easier than actually doing it haga
Absolutely! It's on my someday list as well. Keep up the good work man.
How close does your rear axle come to touching your fuel tank through articulation?cs_drums wrote:I pushed the rear back 1.5" so I had to get a longer drive shaft but that is it. It's basically the 18" most guys are getting plus 3" of up from the notch.
