94 Raptor killer
94 Raptor killer
It's all done. I already did the abs delete, that was a project. For this I just took the loom apart, reroute some stuff, shortened some lengthen others. All new split loom and wrap.
- RyanDS650X
94 Raptor killer
New core support almost done. 6 bolts and the entire thing comes off. Should make working on the front of the engine a lot easier and I can come through the front instead of over when I need to pull the motor.
- Andy Jones
- Bronco Info: In the Works!
94 Raptor killer
Looks good !
Re: 94 Raptor killer
Looks awesome!!! Wanna make me one?
Looks good man!
Clean Brian! Love it. Minimalistic.
Looks awesome!! Really would love to do something like this in the future.
Deslboy
- Bronco Info: 1993 XLT 351. Currently being built. Solo c&t beams, solo radius arms, solo shock hoops
2 questions: Is there a thread on here somewhere about what is all involved to remove the ABS module box and lines?
Other is that I just picked up my 64's today from Geoff at Giant. You said you pushed the wheelbase back on yours. Did you move the front hangers further back on theframerails?
I believe you have to move the hangers I can't remember but it may have been both.
94 Raptor killer
No I just re drilled the spring hangers to locate the pin farther forward. Very common for toyota rock guys.
I just posted the link on Andy's thread for the abs delete. You can do the long way that gets rid of all the wires, relays etc or just jump the VSS wires and tape the extra crud all out of the way.
Must have been Andy that relocated his hangers? I couldn't remember.
Any more on this?
94 Raptor killer
I have a lot less time than I used to for the bronco. Dang career and family getting in the way of my fun!
Pulled it out for welding. Back in now for coolant over flow, steering cooler and a few other little items then out for paint.
I'll tell you one thing, floating the whole front end is a lot more work. My OCD flared up several time needing triple checking several points to be sure it was square. Hopefully nothing moved around during welding.
LOVE IT!!! Cant wait to see it all wrapped up! Nice work.
Really looks awesome!
Deslboy
thanks for the info. Im still a bit confused about how to push the rear wheelbase back. KelFab pushed his back too but never showed any pics or said how he did it. So are you saying that you kept the new front hangers in the factory holes as well as the rears? Did you redrill the spring perches that are welded onto the reared?
94 Raptor killer
Yeah, redrilled the spring pirches
Deslboy
ok. Got it now. thanks. that seems much easier than moving all 4 hangers.
