Oh noes!
This is the rough cut on my knuckles. Remember to wear a breathing apparatus when cutting or grinding cast. The dust is no good for you.
Oh, and my OE balljoints are still good... maybe I baby this thing too much?
Hey Philo, how much would it cost me for 5 method standards in machined finish?philofab wrote:Copied from the "other" site it was originally posted on.
I designed the brackets in 2D CAD and had Erik Shallbetter cut them out for me. A upgrade caliper may work, no way to know without fitting it up.robertcrav wrote:So in theory you could also use any upgrade Cobra caliper as well? Did you design the caliper brackets or where did you pick them up?
Good work and great idea Philo...philofab wrote:I designed the brackets in 2D CAD and had Erik Shallbetter cut them out for me. A upgrade caliper may work, no way to know without fitting it up.robertcrav wrote:So in theory you could also use any upgrade Cobra caliper as well? Did you design the caliper brackets or where did you pick them up?
Yes, in theory. I'm doing something similar and if I was wanting to spend big $$, Baer 4 and 6 piston calipers should bolt on nicely with an adapter bracket.robertcrav wrote:So in theory you could also use any upgrade Cobra caliper as well? Did you design the caliper brackets or where did you pick them up?
philofab wrote:it's way better than mounting to the knuckle.
