BAJANCO
BAJANCO
My new uniball shackles coming soon ,gonna get my Deavers upgraded to the HD version.
Re: BAJANCO
Who is making these? Fab nerding out here and digging the fixture for them. I wish I had a laser or water jet at my regular disposal!
BAJANCO
Richer racing is making them, they built my current set up. They are doing to be direct replacements.ChaseTruck754 wrote:Who is making these? Fab nerding out here and digging the fixture for them. I wish I had a laser or water jet at my regular disposal!
- Becks_Bronco
Re: BAJANCO
Oooof those are nice.Bajaluv wrote:My new uniball shackles coming soon ,gonna get my Deavers upgraded to the HD version.
- Andy Jones
- Bronco Info: In the Works!
BAJANCO
Nice !Bajaluv wrote:My new uniball shackles coming soon ,gonna get my Deavers upgraded to the HD version.
I definitely want a set of those. And a set of their rear hangers.
BAJANCO
Dash is in and layout has begun, probably won’t get all installed before jump champs. Probably just tuner studio, shifter and switches for fans. That’s all I need to race lol.
BAJANCO
Maybe just leave it like this, much easier.
BAJANCO
While cage work was getting tied together I had a storage frame built in the rear to carry my boxes a little easier.
Also had my hood re-glassed at the mounts, they got there ass kicked in the last year.
Definitely had my hands full programming the Rasberry Pi/ LED screen to run tuner studio on start up. Basically I will be running this screen to show real time gauges. As of now it will mount centered on the dash. I’m 87% sure on location My speed will be GPS so as of now there will be no gauges behind my steering wheel.
BAJANCO
I will hVe full control of my ECM/trans running tuner studio. It’s actually pretty cool how much info comes from the ecm. I’m constantly learning, I currently have 2 tunes set up that I’m working with.
- funinthesun95
Re: BAJANCO
Did I ask you if you planned to run a few repeat gauges on driver side a pillar? run 3 gauges Tranny temp, oil pressure, and water temp, with your digital stuff or warning lights maybe
BAJANCO
funinthesun95 wrote:Did I ask you if you planned to run a few repeat gauges on driver side a pillar? run 3 gauges Tranny temp, oil pressure, and water temp, with your digital stuff or warning lights maybe
Yes that’s the plan, made some progress tonight. Probably running those exact gauges on my left side in a vertical layout. Not 100% yet. The screen will be Tuner studio, only a few other things set in stone.
BAJANCO
Installed new stub axle, U joint, spindle, bearings and not going back together. Driver side still seems tighter than it should be, the passenger side has 2 U joints so there is more play.
BAJANCO
Playing with my gauge cluster layout last night. Takes roughly 30 seconds from flip of switch to gauges lots of variations to play with.
Re: BAJANCO
Hey tell us how we can use the stock Obd2 ECU and ditch the PSOM. I don’t want to use a separate trans controller for the E4OD— is that even possible??
BAJANCO
I’m not sure I can answer the question accurately. But I’m currently OBD1. My gauge cluster or should I say speedometer was cable driven. Last year at jump champs I had a fault within my gauge cluster. Greg fro Desolate said just unplug and drive ?? I was able to drive home with a completely disconnected and in the back seat. When I think PSOM, I think 92-96 ? My trans control is integrated into my ECM from stinger performance.VintageIronFab wrote:Hey tell us how we can use the stock Obd2 ECU and ditch the PSOM. I don’t want to use a separate trans controller for the E4OD— is that even possible??
BAJANCO
Coming together, just in time to go race around Glen Helen
BAJANCO
I’m digging this ! Very easy to see adjust on the fly, I can switch to trans and see all function. We will see how bright this is at night lol, might need to dim the screen.
BAJANCO
Jump champs was a success ! Had a few scares in the wash and a K rail. We raced door to door and that’s what made it a blast, took home third.
BAJANCO
K rail
“O” rings or seals, haven’t opened her up yet to see
Also convinced the wife to ride in the backseat, she had a blast !
- Needles929
- Bronco Info: 95 Part Deux
