Carly's 96
Carly's 96
Looking good, Randy!
Carly's 96
Thank you Andy. It won't be as crazy as yours but itll go where it needs to.
madmatt1
Bronco Info: 1995 White XLT, daily driven work in progress.
Re: Carly's 96
Post by madmatt1 »
tcm glx wrote:Progress looks nice Randy.
Good deal here on knuckles ready for swing steering.
https://classifieds.race-dezert.com/FOR ... les-161401
Word of caution, those are off of a 1990, and have a six bolt pattern, your 96 is five bolt. You'd have to have the spindles, hub/rotors, etc for the 1990...
I saw those yesterday and got really excited, for a moment! I have a 95.
Carly's 96
Thank you I saw that. I remembered that being an issue.
Carly's 96
I made the first plate and tacked a stub to it. The front will land on the hump with 4 bolts. No bends as I like the look of the welded tubes vs bent. Also I save room. ImageImage
Carly's 96
Got the front mount for the passengers side cut out and holes drilled. Just need a piece of tube and 4 holes in the frame and I can tack together the passengers side ImageImage
Carly's 96
Don't judge too harsh final fitment isn't done just tacked to configure tubes. Still need the front tube and plate done ImageImage
Pickuptrucker
Re: Carly's 96
Post by Pickuptrucker »
Good progress!
Carly's 96
Tacked and waiting for the shock tabs I ordered from ruff stuff. Image
Re: Carly's 96
Pickuptrucker wrote:Good progress!
Thank you. I try to get to it when I can. The tube has been sitting for 7 months.
Re: Carly's 96
Well done, Randy! We'll make a fabber out of you yet. :D
Re: Carly's 96
AussieRod wrote:Well done, Randy! We'll make a fabber out of you yet. :D
Ha thanks Rod. I learned alot building my vw. Part of it is wanting to say I did it the other is the ever pesky wallet
Carly's 96
Kick ass, Randy! Looking good.
Re: Carly's 96
Andy Jones wrote:Kick ass, Randy! Looking good.
Thank you Andy! Looks like I'll have room for bumps up front so mounts will be made. I have to replace the steering so I'm figuring on a swinger setup. Got alot to go but it's taking shape.
Carly's 96
Four revisions and more time than I'm wanting to admit and I have beam shock mounts. I should have the tabs from ruff stuff for the engine cage on Friday then the lower shock mounts to cut out of 1/4" plate. I maybe able to cycle the suspension this weekend and see how much I screwed up the shock position.Image
Carly's 96
My ruff stuff tabs showed up today and I cut out the lower shock mounts, tacked them on the beam fitted tubes and cycled suspension. I'm leaving some room in case I end up going with glass for more bump travel. I think my shock shafts either have a short rod or a spacer. I'll have to take them apart to find out. ImageImageImage
Re: Carly's 96
Looking good!
Re: Carly's 96
ChaseTruck754 wrote:Looking good!
Thank you Steve. I'm capping the ends with 3/16" tear drop plates so the ends are closed and more weld area. It makes me feel a bit better.
Carly's 96
Ok done for the night. Just need to gusset the shock mounts and add tabs when I get the driver's side done.Image
Pickuptrucker
Re: Carly's 96
Good progress
