Philo's 93 Bronco aka "Lucky Bronco #3"
Re: Philo's 93 Bronco aka "Lucky Bronco #3"
Transfer case parking brake....
philofab wrote:Image
More details... i may have to steel this idea
cs_drums wrote:More details... i may have to steel this idea
Me too. Haven't had a parking brake for years.
What rotor is that Philo? Off a Civic or something?
The bolt pattern on the flange is 4x108 or 4x4.25, which happens to be the wheel bolt pattern on many small cars.
This exact rotor is from a 1981 Ford Escort. Cost is $18, and part number is 6082RGS.
I have not decided if I am going to run a mechanical only caliper or a parking brake style hydraulic caliper. Having a big lever to throw the truck sideway before drifting a corner could be fun....
Bondobob
Post by Bondobob »
Nice, I hadn't even looked at the import. I have some Airheart part numbers of the mechanical calipers I was looking at . Rotor with a diameter of 7-8" was my target for the flanged 135 transfer case and floor clearance.
Are looking at a change of direction on the OEM cable on the frame ??
Bondobob
Post by Bondobob »
1356 transfer case
I am not using any of the factory parts, the foot pedal is right where the cage will be. I will be using an equipment style handle.
Phoenix0783
Post by Phoenix0783 »
philofab wrote:Having a big lever to throw the truck sideway before drifting a corner could be fun....
Seems like that would be really hard on the ring and pinion with that setup.
Phoenix0783 wrote: Seems like that would be really hard on the ring and pinion with that setup.
Maybe, new rearend has a 10.5 inch ring gear. Can't see it being harder than 450+ hp through the rough. Loading and unloading is harder than loading by itself.
Got parts in from Ruff Stuff Specialties & Midwest Control.
Next up is machining spacers for a through rod to keep the rear end straight for welding. Gotta make a bolt list too and order that stuff.
I also ordered a sweet seat adjuster from Tommy T at Poly. Girlfriend wants to drive the Bronco so I have to make it adjustable for short people. Should be scary since she has little driving skill.
philofab wrote:.....Girlfriend wants to drive the Bronco so I have to make it adjustable for short people. Should be scary since she has little driving skill.
I predict a "Philo's Lucky Bronco #4 " thread in the near future! :lol:
Real excited to see this set up come together. Did you say you're doing 72-73 wms for the rearend?
cs_drums wrote:Real excited to see this set up come together. Did you say you're doing 72-73 wms for the rearend?
More like 71", shooting for 3" wider per side.
What's that miniature radflo looking shock? Servo assist?
And the 2 chain link looking things? Prebent sections of tube?
Rmc wrote:What's that miniature radflo looking shock? Servo assist?
That looks like part of the DD Link from Giant :roll:
That is part of the DDL setup from Giant. The allows the axle to articulate on the two link, absorbs driveline shock, and causes a sway bar affect.
Rmc wrote:And the 2 chain link looking things? Prebent sections of tube?
Those are the axle mounts.
I have a lot of people tell me this system won't work... Funny, it rides really nice and works great on Craig's Ranger and Geoff's Bronco.
Reminds me of a modified class dirt track car rear end set up.
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
Ya, I don't understand why some people are so against a panhard bar. Sure it's not ideal but from what I've seen it works great. Can't wait to see you blowing past the haters.
