Brian's '96
Dezertbronco
- Bronco Info: 1990 Bronco EB
Re: Brian's '96
Theres a couple on craigslist. BTW you have a PM.
Re: Brian's '96
It turns out the reason the pump was shot in the manual case is because the channel that the anti rotation arm is contained in had worn through, allowing the pump to spin. See the first picture below.
This is the case out of my '96. Halway worn through after 160k.
Re: Brian's '96
Hmmm. I might have to open mine up and do a little bit of welding.
Re: Brian's '96
Turns out I would have had to tear both cases apart anyway. The rear output shaft in the manual case would not have accepted the flange from my electric. Went ahead and installed the updated planet. Hope it works!
Here's my po-dunk fix for the anti-rotation woes. Should hold up ok.
It doesn't appear square because the shaft is leaning without the rear bearing to support it.
Re: Brian's '96
Had Ford done that you probably wouldn't have had to fix it.
Re: Brian's '96
She ugly, but she ready!
Re: Brian's '96
How is the shifter already on it?
- bajascott
- My belly is my best friend
Re: Brian's '96
its missing the 8 ball for a handle Brian....
Re: Brian's '96
Well, screwed.philofab wrote:How is the shifter already on it?
Re: Brian's '96
Alright fellas. I need a different control rod for the shifter. The one I have is for a C6/T18 and obviously I need it for an E4OD. Ford shows them as obsolete. Nobody has them. I also need the shifter detent plate. Or is that really necessary? Help!
Re: Brian's '96
I'll see what I can come up with.
Re: Brian's '96
My future co-driver. I'm getting all teared up again.
Re: Brian's '96
Whats a control rod? I have the complete E4OD set-up here if you need any parts.
Re: Brian's '96
BDKW1 wrote:Whats a control rod? I have the complete E4OD set-up here if you need any parts.
Thanks Brian. C6 version in the picture below. Scott has one that he's sending my way. Have you got a shifter boot in good condition by any chance?
- BajaF250
- Bronco Info: 1982 Ford F250
Re: Brian's '96
Hey Brian,
When I converted mine, I just fab'd one up... I thought I'd spend more time looking around than than it took to make one. The other beauty of it is, you can custom position the shift lever if you so choose. Just a thought.
Re: Brian's '96
Boot is in perfect shape. The plastic base is cracked in half....... If you want it PM Me your address.
Re: Brian's '96
Knocked out most of the body mounts this morning...
Re: Brian's '96
Chiney!!!! I like.
Re: Brian's '96
Picked up some goodies on the road trip with Nick today. Got meet John and Darren at Autofab and stopped by Kartek on the way back. Woohooo! What a great day.
- bajascott
Re: Brian's '96
cool! i need to pick some thems up for me.
