95 Bronco Build!
Re: 95 Bronco Build!
philofab wrote:Travis! Make me some bedsides that move the rear axle 5" back and can handle a 86" outside to outside measurement, probably a 5" flare.
I want more wheelbase and rear driveline!
How about using an F150 bedside? Hang the extra length of the back of the truck and use that extra space for storage (spares, gas cans and such). Not my idea... Mark Newhan came up with that one but I always thought it was a good one.
ESHALLBETTER wrote:Image
I don't understand why the action packers aren't made so they stack better. I like the idea of them but the fact that you can't stack them and cinch them down real tight sucks.
I agree. Action packers not action stackers I guess. I've looked at them quite a few times already but still haven't pulled the trigger.
drewbee88
Post by drewbee88 »
Ditto. I was looking at my bronco last night and I'm looking to move my wheelbase back as well.
We have the retro Bronco bedsides that move your wheel back 12" or the Raptor conversion bedsides that move it back up to about 3 inches. As soon as I get this housing under my truck, I am going to do a larger set of 5" or so bedsides that have a nice flat top. When those are done we will be able to lengthen them for people to any wheel base.
I moved mine back about 2" and the rear end is barely clearing the x member I think 5 would be the max with the stock tank and building a slimmer x member.
I don't want to lengthen the Bronco... just move the rear wheels back...
A truck bedside might work if I shorten the back half...
cs_drums wrote:I moved mine back about 2" and the rear end is barely clearing the x member I think 5 would be the max with the stock tank and building a slimmer x member.
Planning on getting rid of the stock tank and x-member if I lengthen wheelbase... My panhard requires more room anyway.
Panhard? Are you gonna run Geoff's DD link setup?
ChaseTruck754 wrote:Panhard? Are you gonna run Geoff's DD link setup?
Yes.
philofab wrote:I don't want to lengthen the Bronco... just move the rear wheels back...
JD fabrication did this on a bronco(there are pics of it floating around here somewhere) they were able to get auto fab bedside to look pretty good by sliding them back and re working the rear and wheel well. Fuel cell, rear all reworked and paneled in. Its really nice. Its on their site.
I plan to do this in the future too. Not soon but once I get over how well the it works in its current state. :D I already have the tank drawn up and will only need to rework 1-2 tubes on the cage and the x member. I am really happy with the 64 kit so I may just slide the mounts back to avoid going through the floor with upper links. Geoff's DD link set up would mitigate that but I want to see how much life I can get out of my 64s before I take the link route. They work really well.
cs_drums wrote:JD fabrication did this on a bronco(there are pics of it floating around here somewhere) they were able to get auto fab bedside to look pretty good by sliding them back and re working the rear and wheel well. Fuel cell, rear all reworked and paneled in. Its really nice. Its on their site.
I have never seen that Bronco with bedsides on it.... Where is Party Barge when you need him?
Travis: What did you eve figure out on wheels? I sent you a message...
No I still need wheels, I dont have your phone number! PM it to me
Got some axles on order. Pumped on these!
Little prep action, doubt this thing has ever been off! Taking care of the leaky axle seals and diff cover.
crisis88
Bronco Info: 94 fsb stock
Post by crisis88 »
Travisfab wrote:Got some axles on order. Pumped on these!
Nice!!! Spensive!!
crisis88 wrote:
Travisfab wrote:Nice!!! Spensive!!
Yeah, probably more than what my truck is worth if it were stock!
Nice Travis! That's what I've been dreaming about. Heck yeah! Glad someone finally pulled the trigger on those.
They are very nice, too expensive for my blood though. Let us know how well they work.
Brad Lemarche has been running them on his TORC formula Bronco for a couple seasons now and has only had one problem I believe using them in race conditions with a fire breathing engine.
Good purchase!
crisis88
Post by crisis88 »
I believe one of "The Factory Racing" guys is running them also. And they have been hood from what I understand.
