Kel Fab Creations wrote:Hmm. I haven't experienced the rad arm to beam bolt loosening up before. Are you speaking from experience or heard it from someone? Was locktite and/or a lock washer used in these instances?
Well, all but one pair or radius arms I've used had the third mounting point so, no, not really personal experience with that. I have had reports of the issue from plenty of reliable sources, though. Unless the truck is exceptionally rigid, the distance between the corresponding radius arm and axle-housing pivot changes slightly and the beam and arm are squeezed and spread... wanting to rotate on the arm/beam bolts. Once my brother's Explorer is dialed in, I'll add a third mounting point to the front of the radius arm so I don't have to deal with it later. It's a little more work but cheap insurance.
