95 Black Bronco
C H O
Bronco Info: 1993 Lightning
Re: 95 Black Bronco
Post by C H O »
Image Image
Re: 95 Black Bronco
Lovin in the updates. How much travel are you getting out of the front?
C H O
Re: 95 Black Bronco
Post by C H O »
Thanks, it cycles 20" with out the third member
Re: 95 Black Bronco
20"?!?!?!? That's pretty freaking awesome!
Re: 95 Black Bronco
CHO - anyway you might be able too uno the rear coilover to the lower trailing arms? They are just so damn sexy in that capacity and I'd love to see your design in a set!
C H O
Re: 95 Black Bronco
Post by C H O »
Im going to keep it off the axle and lean it forward, trying to keep things as simple as possible, all of my rear tube work is already done to be set up that way too.
Trever Leach
Bronco Info: 93 bronco building using giant motorsports parts and my garage fab skills. family wagon prerunner
Re: 95 Black Bronco
Post by Trever Leach »
looks good Cho.
Seabass
Bronco Info: 96 bronco
Re: 95 Black Bronco
Post by Seabass »
Vintageironfab Shock tuning and stability should be better with the shocks on the axle. Ratio can be 1:1 making valving easier to figure out. This is my take on it. It may even help with the need of a sway bar to some extent.
C H O
Re: 95 Black Bronco
Post by C H O »
Thanks Trever! Seabass, the opposite is usually the case with the shock off the axle, the faster shock shaft speeds make it harder to dial in right. Im confident I can get it working well though, kellan set the rears up based off of what they have been doing on Michael Cox's truck and his seems to work amazing, actually his truck sas the one that gave me the motivation to go this route. Regardless im sure it will be better than leaf springs, and running the stock axle was the only thing keeping me from links in the first place.
Re: 95 Black Bronco
Looks Killer Cho ! Your Bronco is definitely making me save up the dough, to drop mine off with you. Trying to get mine to the rolling stage, so I can finally make the call !
Rustbucketracer
Bronco Info: 1993 BRONCO, grocery getter
Re: 95 Black Bronco
Post by Rustbucketracer »
Nice work. It was cool meeting you, Billy from The Cellar.
C H O
Re: 95 Black Bronco
Post by C H O »
Thanks Andy, Looking forward to that day!
Nice meeting you too Billy, im sure Ill see you around soon im local to the area.
C H O
Re: 95 Black Bronco
Post by C H O »
Sorry i haven't updated in a while, but I haven't stopped making progress. Link mounts are complete on the truck and housing, rearend is hung, and im figuring out shock mounts now.
Re: 95 Black Bronco
What's the reason for using that style 4 link vs the more common one? You and Mike (Smart Alex) both chose that style...
Re: 95 Black Bronco
WOW! Looks great ![THUMBS UP SIGN]
cypher
Re: 95 Black Bronco
Post by cypher »
Andy Jones wrote:WOW! Looks great ![THUMBS UP SIGN]
x2 soooooo nice.
Re: 95 Black Bronco
X3 looking good man!
Re: 95 Black Bronco
Such nice work!!!!! can't wait to see it in person.
Re: 95 Black Bronco
Andy, he said in an above post that Mike's truck inspired him to go this way. This version is slightly lighter on fab, which is why some guys choose it, although with Cho's skills I doubt this is the reason.
I had heard this setup was a bit easier to tune shock wise, but in the same post where he mention's Mike's truck above he also says shock tuning this way is harder, not easier.
C H O
Re: 95 Black Bronco
Post by C H O »
Thanks everyone for the kind words. With a e40d in the stock location shock off the axle is a no brainer. Packaging is very tight on these trucks, and with the stock drive shaft angles i couldnt justify building full link arms, cutting the crap outta my cab, and killing passenger space with tube work. For what i want out of this truck im sure it will far exceed my expectations. Party on!
