Carlos83 1983 Bronco
Re: Carlos83 1983 Bronco
Carlos83 wrote:
ChaseTruck754 wrote:Yes he does.
But it shouldn't matter - you should be updating to 92-96 anyways :lol:
thanks but no thanks.
with all respect sir
i'll try my best to keep this 83 with an 83 clip.
Well said, Carlos, you are a true champion to our cause. :mrgreen: On behalf of all of us at APEMFB, I welcome you to this forum and look forward to seeing the progress on your machine.
aamay1986
Bronco Info: 1986 Bronco 6inch super lift, 5.0 efi. 4.56 gears. 9inch, bilstein 5100 shock, 35in bfg mud tires.
Post by aamay1986 »
Welcome to the site Carlos, nice bronco, the more time I spend on here the more I want to build something similar to yours. Stay with the 83 front it's going to get harder to come by a clean one soon.
Carlos83
Bronco Info: 83 351W GT40P 35BFG AT "Tijuana Special"
Post by Carlos83 »
i found this pic in one of the FSB threads. pretty neat ad
Carlos83
Post by Carlos83 »
updates are so sloooooow!
i wanted it ready by the B500 so. it wasn't , so I had to hitch a ride last weekend..oh well
back to the thread:
i am done with the wiring and started installing the gauges into the fiberglass dashboard...
i removed all the stock wiring in my dash (not really much of it.. this is a 83 bronco custom...no EFI....and the wimpy DuraFart III Controller went away in '99)
from this:
to this
(driver's side view:)
closeup:
now, the dash looks not su bad with the gauges:
another shot:
I am ready to order my limit straps and extended brake lines.
sooo i lifted it to check the droop.....
here's the rear droop:
here's the front:
finally i am having a hard time figuring the best way to mount the spare tire.
Flat on the floor looks the best. but i will loose all my cargo floor
vertical facing the rear frees up some space, but i will loose rear view (i dont have a rear view mirror since 2001)
what do you guys think?
oh well... i will figure it out
i will post updates as soon as they happen
bajabuck
Bronco Info: 87 Bronco with some Autofab parts held on with bailing wire and duct tape
Post by bajabuck »
Check out Keifer's set up. Southwest Performance.
