Brian's '96
Re: Brian's '96
Started working on the plumbing. Does the pressure line look like it will be fine, or is the radius too tight? I don't have the specs on this specific tube, but I suspect it's supposed to be 3.5-4" minimum radius. I ran my last line similar without fail, but want to make sure it's right.
keenanduran1
Brian's '96
Post by keenanduran1 »
Re: Brian's '96
Hahaha
Re: Brian's '96
No idea Brian, try it and watch the temp? Hopefully someone else can chime in.
Re: Brian's '96
Nice and shiny... sure it will work, if it looks good, it has to work good right?
Jonerton15
Bronco Info: Linked 4x4 prerunner ranger. Looking to get rid of it and get into the bronco scene.
Re: Brian's '96
Post by Jonerton15 »
You're good. Minimum bend radius is 4"
Re: Brian's '96
That pump won't work with just one line...
Re: Brian's '96
keenanduran1 wrote:Image
Nipples!!
Brian's '96
Finally...After fighting with customs for over a week...
Re: Brian's '96
Thats sexy... does the Amber work off a seperate switch Robert? Or does it all light up together?
Independent switch
Brian's '96
That looks sweet, what did that run?
Re: Brian's '96
don't want to clog up Brians thread, ..... shoot me a pm
Re: Brian's '96
The light bar is nearly a perfect fit with the old bumper and looks great. Thanks Robert!!
Got new rubbers mounted up. I think I'm getting too old to mount beadlocks. Wanted to take a nap when all finished. Haha! Next time I'll pay someone else to do it.
Used washers to shim the pump. Planning to make weld-on spacers for the adapter bracket to replace them.
Mounted the Howe reservoir for easy access to check the fluid level.
Finished the plumbing.
Put 200 miles on it in the last week with no issues. Totally jazzed. Steering is buttery smooth, but still a nice amount of feedback. Can move boulders now. Heading to the Eastern Sierras in a few days to give it a good workout. Can't wait!!
Cactus Cooler
Re: Brian's '96
Post by Cactus Cooler »
Hey Brian what spring rate are you running on the Coils?
Re: Brian's '96
246lbs single rate. They're just a bit light, but work ok as long as the nitrogen pressure stays up around 200psi.
Looks awesome Sir! Good meeting up with you this morning
Hell ya! Looks great. Take lots of pics on your trip to the Sierras, I've always wanted to visit that area.
Rustbucketracer
Bronco Info: 1993 BRONCO, grocery getter
Brian's '96
Post by Rustbucketracer »
Truck looks great Brian!
nubreed71
Re: Brian's '96
Post by nubreed71 »
Brian, that frontend shot is a work of art. Nailed it!!!
