Tonys 93 bronco
Re: Tonys 93 bronco
Ive got 600-700 into it Ryan. I dropped counting. Haha
- RyanDS650X
Re: Tonys 93 bronco
600! Dang that thing truly is a mini me. It has a budget to scale in addition to the size scale lol!!
- Silverslk
Re: Tonys 93 bronco
HA!!
Tony quit counting money spent on the real Bronco AND mini-me Bronco..... that says it all!!!![Smile :)](./images/smilies/icon_e_smile.gif)
Re: Tonys 93 bronco
These damn hobbies are not cheap. I'm gonna take up paper airplanes.......might be a cheaper option!
Re: Tonys 93 bronco
Clean those tires for goodness sake. How's it supposed to mimic the garage queen with trash like that?
Re: Tonys 93 bronco
New wheels and tires are on the way, she'll be show quality by leduc. Still workin on the mudflap. Ha!
- Bronco Info: It's a non Bronc! the bronco's larger cousin with a bed, a 95 f1
Re: Tonys 93 bronco
17's?
Re: Tonys 93 bronco
Whoops, you meant the rc haha, my bad!
Re: Tonys 93 bronco
Yes the RC. Haha.
Re: Tonys 93 bronco
What the heck... three pics the same ,not what was supposed to come out there.
Silt Sucks!!
![Image](http://i137.photobucket.com/albums/q207/tcmglx/2015%20Los%20Amigos%20Excursion%20Prerun%20Pics/DSC_0093_zpsty70n5ur.jpg)
![Image](http://i137.photobucket.com/albums/q207/tcmglx/2015%20Los%20Amigos%20Excursion%20Prerun%20Pics/DSC_0071_zpsj7ogbgve.jpg)
![Image](http://i137.photobucket.com/albums/q207/tcmglx/2015%20Los%20Amigos%20Excursion%20Prerun%20Pics/DSC_0064_zpszb8lmelp.jpg)
Im going to try and retrofit these into the headlights:
http://www.bajadesigns.com/ProductDetai ... ber=550001
Silt Sucks!!
- 1Hondalover
Re: Tonys 93 bronco
Thanks for the invitation Tony!
What.....you didn't invite us because I don't have your lights mounted yet?
Geez I'm working on it.
Re: Tonys 93 bronco
No lights, no invite!!! Kidding Jim, invite will be coming soon, this was more exploratory in nature. How's the Bronco?? no updates, what gives.1Hondalover wrote:Thanks for the invitation Tony!
Re: Tonys 93 bronco
Hey Tony, Did you wind up moving the "slider stopper" collars up since the AGM sliders are taller/longer ... I imagine if not that would limit up travel?tcm glx wrote:Well, a big thanks to Jose, he spared most of his morning this weekend on Friday to help me pull out my coilovers and swap out the sliders and lower coil springs. The AGM sliders really are nice.... very nice quality.
And yes, I know the springs are not pointing in the same direction. I will pull and fix later. The other side is in alignment.
Before
After
Re: Tonys 93 bronco
I did readjust my collars. I only allow for about 1.5-2" of up travel before allowing the slider to hit the collar. The reason being is I want the upper spring rate to help with the highway ride, and light trail ride if you will.......but then once it has gone up about that 1.5-2" (which isn't the aval amount of up travel because this is measured at the shock) and then actually get into the combined spring rate. That doesn't. Limit overall up travel at all, just gets into the combined spring rate faster.
Re: Tonys 93 bronco
Gotcha...
Re: Tonys 93 bronco
Once it hits the collar, wouldn't that take the upper spring completely out of the equation since the slider can't move any higher up the shock body? At that point you wouldn't be using the combined spring rate, it would be just the spring rate of the lower spring since that's the only spring that can compress at that point.
Re: Tonys 93 bronco
nubreed71 wrote:Once it hits the collar, wouldn't that take the upper spring completely out of the equation since the slider can't move any higher up the shock body? At that point you wouldn't be using the combined spring rate, it would be just the spring rate of the lower spring since that's the only spring that can compress at that point.
Sorry yes, explained it backwards, combined spring rate until it hits the collar then basically on just the lower spring rate.... Damn mall crawler catching my mistakes HAHAHA
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Tonys 93 bronco
Gotta impress the soccer moms in the grocery store parking lot!
