Philo's 93 Bronco aka "Lucky Bronco #3"
Re: Philo's 93 Bronco aka "Lucky Bronco #3"
philofab wrote:I just ordered some shocks from Joel for my trucks. He is building some "9200 Huckmaster Series" shocks just for me so I can school you fools! Lol.
Bilsteins FTW!!! What is he doing to them Philo? Radiators, and ACVs?
tcm glx wrote:Bilsteins FTW!!! What is he doing to them Philo? Radiators, and
ACVs?
ACVs and a Voodoo Shaman is blessing them.
You doing the rears also Philo?
tcm glx wrote:You doing the rears also Philo?
As soon as someone buys my bypasses.
I scored some tires for the Bronco today in Vegas. They have 1 race on them but will have to do since they are still on back order.
navynuke
Post by navynuke »
awesome deal on the tires, got the shocks all mounted up and replaced the broken junk in mine today.
Looks good, can't wait to see how they feel compared to the junk I had on mine.
only1mikey
Bronco Info: 84 Bronco
Post by only1mikey »
Truck looked good at the Clean Up.
How much you selling the bypasses for I could use them for my truck.
Mike
only1mikey wrote:Truck looked good at the Clean Up.
Mike
Looking for $900 for the pair. I may have them traded off for a set of APPs plus cash though.
Pulled the rear end apart to repair a loose reluctor ring and gear whine. Found this.
just stick weld it and call it a day......
that sucks.
Damn Philo, what causes that?
Holy Cow Philo! Good you found it now instead of out on the trail somewhere.
Silverslk wrote:Damn Philo, what causes that?
Ahem......
RSR
Post by RSR »
Philo obviously employs the SSS driving technique...
Stomp on the gas
Stay on the gas
Steer
:lol:
Just ordered a Yukon nodular 3.25 case and some spacer bearing races from Giant Motorsports. Should be here Wednesday.
After removing the rear drive line I spotted a hole in the accordion boot. Also my output flange is way loose on the splines. Hopefully the flange is softer and the main source of wear.
I just realized I have not put many pictures up lately. I'll have to fix that. This is me trying my best to be a rock donkey.
Also, a naked pic.
I thought I had hurt the motor at the Mint 400 due to a horrible miss it had. Just ended up being a bad plug. Electrode was melted to the tip. I was worried but cylinder #8 checked at 150psi and it cleaned up with new plugs and a MSD cap/rotor.
navynuke
Post by navynuke »
always nice when its an easy/cheap fix.
My 10 dollar junkyard starter is working great.
#8 is always the first one to go.........
BDKW1 wrote:#8 is always the first one to go.........
I figure that cylinder runs the hottest as it it farthest from the water pump and also the ambient around the motor there.
