Different Use for Tire Swing Hinge?
I know it's not a 'new' idea, but since most of us ditch the factory tire swing, has anyone removed the tire carrier part and left the hinge mounted to the body to use as a whip and/or antenna mount? Like maybe just the upper hinge?
95bronco12
Bronco Info: 1995 bronco 5.8 4inch lift on 33's
Re: Different Use for Tire Swing Hinge?
Post by 95bronco12 »
Exactly!
Cool idea!
I have been working an idea to use mine to build a tower for long range race radio. Back in the day, when my dad and I use to char, we would set up a tower for longer range reception.
Nice....year or so ago I had seen a pic of a guy that used the hinge pin hole for a whip and drilled another hole closer to the body for a cb antenna...and I saw a cb mounted 'normally' to a tire swing on the freeway so wanted to bring it up and document it.
Tony would the long range just be for when you are parked?
robertcrav wrote:Nice....year or so ago I had seen a pic of a guy that used the hinge pin hole for a whip and drilled another hole closer to the body for a cb antenna...and I saw a cb mounted 'normally' to a tire swing on the freeway so wanted to bring it up and document it.
Yup. We carried three poles that were 5 ft talk each. The slid into each other. My dad had a mount clamped to the rear tire swing. I'd like to do it more permanently into the swing portion. I have two spare tire carriers at home for it.
When you set up a remote pit, pull out the poles and run a second antenna. Ez pz.
