New here xlt bronco
- THEJESUS
- Bronco Info: 1992 BRONCO XLT
New here xlt bronco
What's up GFB the names Jesus
I have a 92' white xlt bronco
Here's a little info about it
As it sits now in the photo
-35" toyo open country m/t on eagle alloy rims
-2" lift I believe
- pacesetter headers with cat delete and magnaflow muffler 3" piping all the way out to stock location
- 130 amp mustang alternator conversion
- MSD ignition setup
- kenwood system with 12" sub
- front and rear bumpers
-50" light bar up top and 24" on bottom
-4.56 gearing
All I can think of for now
Here is some pics of how it sits right now
-2" lift I believe
-4.56 gearing
- image.jpeg (188.67 KiB) Viewed 2218 times
- THEJESUS
Re: New here xlt bronco
Here's a few more
- image.png (805.52 KiB) Viewed 2217 times
- image.png (859.58 KiB) Viewed 2217 times
That is a nice ride.i was thinking about buying the solo motorsports entry level kit. But first i need to fix some things. I live up in the desert in so cal. When just cruising rather 4hi or 2 if i creep over sometbing a little off camper it starts popping. Not sure what that may be??? That and the power steering leak.
- THEJESUS
I've looked at the solo stage 4 setup and almost pulled the trigger on it but I found a alternative to that and just as good of quality work. Not to sure what that noise could be. this thing also has the power steering leak and few other leaks I need to fix soon.
What did you find? I i know giant motorsports and autofab has some LT kits. All my buddies that have owned Broncos and every single one leaked. What all is yours leaking? You have a 351? I got 33s on mine and when i take off at medium throttle my truck only likes to shift at 2k rpm unless i get heavy in the gas is that normal
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
welcome,
good looking rig, looks super clean.
- zachwabbit
Nice bronco!! Welcome!
- THEJESUS
Thanks for the welcoming! dtb, zach, and s00t!
Hazard I am going with a guy that is local to me which is flight industries I believe he only works out of his house but his work is next level!
I will be going 4.5+ up front with kings and kings on the rear and deavers when I get the money for the rear.
for the leaks well power steering, rear main seal, brake master/booster all the important stuff
Flight is Rbert or RMC on here. He does good work & is a helpful guy. Good choice.
- THEJESUS
Chas, yes Robert! Great guy and can't wait for him to get started!
- THEJESUS
Chase, yes Robert! Great guy and can't wait for him to get started!
- THEJESUS
New here xlt bronco
Thanks Steve
