Hello All,
I am Andrew from the northern VA area. Lurked and read for a while, but figured I should go ahead and register. I have a 94 XLT 5.8/E4OD bought in 09 that is still mostly stock. I have a lot of parts waiting to go on but, not the parts I need right now. I have Autofab fenders, fender tube frame kit, quarters and hood sitting in my shop from a trade I made a few months ago.
My goal is a daily driver that handles gravel, fire roads and drive on beaches at speeds. I am pretty sure I want cut and turn, extended arms, 5.5 deavers, Deaver rears, 5100's, and 35at's. Have a lot of ideas about what I want, but need a lot of advice.
First question though is about my 5.8 . Had the motor out a few years ago and have not been able to get rid of a cold weather belt squeal since then. I think it is due to the ps pump pulley but not sure. Any thoughts? Second is that I have not been able to get the thermostat housing to totally seal since then either. seems the face on the manifold has warped or something. Thinking of replacing with the Edelbrock efi intake, but that is big money. Any thoughts on that?
Thanks.
Drooopy
New guy from Va
New guy from Va
Sounds like you have a good plan. I just moved to Virginia Beach this week. Not sure how far you are but if you need help with anything hit me up. My bronco is still in San Diego so I am having withdrawals.
- johncharlesb
Re: New guy from Va
Welcome. Post up the questions in the general tech or Steve will scold us.
Check to make sure it is not a distributor bushing going bad; they can sound like a bad belt and come from the same area. A huge screwdriver is a superb stethoscope.
The thermostat housing would likely be warped before the manifold is my guess. It could be improper torque, or just corrosion. I would bitch slap some liquid copper on it and bolt it up.
I would save the money from the edelbrock manifold and apply it to Bistein 7100s.
Drooopy
- Bronco Info: 94 XLT 351W/E4OD Mostly Stock
Re: New guy from Va
Hope you get the Bronco over soon. I am up by Dulles.cs_drums wrote:Sounds like you have a good plan. I just moved to Virginia Beach this week. Not sure how far you are but if you need help with anything hit me up. My bronco is still in San Diego so I am having withdrawals.
New guy from Va
It's likely gonna stay in SD so I can use it when I go home for thanksgiving. Gonna do a mild build of something out here to keep me occupied.
Re: New guy from Va
Welcome to the forum Andrew. I have a buddy who lives in Va. I'll be looking forward to your build, since you already have some very drool worthy parts!!
