For sale abrasives and burr king belts
For sale misc abrasive belts for burr king. Some 60 grit, some scotch brite red, misc Bosch screw on scour pads and grinding wheels. Make offer.
Re: For sale abrasives and burr king belts
Size?
My guess is 2" x 60" but if they happen to be 2" x 48 I'm interested.
Bondobob
Post by Bondobob »
If they are 60" I'd be interested.
I'll get u guys some measurements, I believe there 2 inches wide but ill confirm. Ill also get u guys an arbor diameter/ disc diameter for the other wheels. I have no burr king just got this stuff in a combo auction deal.
The belts may have the dimension on the inside of them.
I can see a 36 in the pic above, but are there any other grits for the belts? And are the scotchbrite belts the same size as the sanding belts?
Also - can you get any pics of the "screw on scour pads" and do you have any scotchbrite type "grinding" wheels in the lot?
I'll go have a look.
Qty 8 scotch brite red belts 1.5x60"wide,qty11 36grit sanding belts 2"x60, qty 11 4.5dia grinding wheels screw on arbor type 5/8-11 thread, qty 9 part off wheels 5/8-11 screw on arbor type, all grinding wheels Bosch brand, scour pads unknown. Scour pads will need some type of arbor or holding device. Qty 24 on scour pads 4 in dia 1/2 in thick.
...misc drum sander stuff too, 1.5 and 1 inch dia.
Damn - all yours Bob!
I may be interested in some of the 1" drums and grinding disks/parting wheels depending on what you want for them. That's about all that will work for me though
I'm open to trades also, I'm looking for any 5 on 5.5 17x8 or 8.5 wheel, steering wheel, seats , bumps, bump cans, storage boxes ( action packer type), let me know what's floating around your spare parts piles. I can throw cash on my end for the right deal. I also need a tig peda( 14 pin miller)l, empty owned ( not rented)gas cylinder, tt style swaybar/ arms ect, autometer gauges, 14 inch coil overs, let me know what this stuff is worth to whoever wants it. Pm me if u like.
A new working condition bronco factory air ac compressor is on my "to acquire" list also. R134a. Also a beadroller, bench top brake, lathe insert tools, 5c collet set, pretty much anything.
Bump. Trade pending on sanding belts.
Bump
Belts have been gone a while, still have the other abrasives.
Bump
