Purchased from original owner in 2015 then built over a 1 year period. 4.5 over Threat front with Kings and 2.5 Bumps. Rear is a Currie F-9 w/ Detroit locker, 35 spline and disc brakes on Deaver Q-80's to Threat shock mount and shackles. Shocks tuned by King at Barstow. Shocks and deavers just freshened. Threat engine "race cage" with 4 tubes through firewall to 1.75 DOM full cage. Mastercraft seats on sliders, mastercraft bench in rear. 156k on motor, 3k on rebuilt trans (nothing was wrong I just did it). Replaced A/C system, heatercore, aluminum radiator, aftermarket gauges. K&N system, and CA smog legal. Full Dynamat interior with new carpet and headliner. Built to take the wife and kids prerunning in Mexico... they dont want to go anymore, so im going back to a 2 seater. Cruises down to Mexico at 70 MPH... preruns without a worry.. and comes home. Adult owned and very well maintained, you can drive this thing anywhere.
1.75 full cage
Solid body mounts
Solo solid engine mounts
VSS relocation
ABS delete
Wilwood bias adjust
Method wheels
Pro-Comp tires (W/2 mounted spares)
Fiberworks Glass
Optima Battery W/Disconnect
Lowrance GPS
ICOM Radio
Removable roof rack (holds gear or additional spare if needed)
30K 559 308 2063 Tom call or text
Thanks for looking.
96 Bronco Prerunner
96 Bronco Prerunner
Re: 96 Bronco Prerunner
a few more pics.
also forgot to mention 4.56 gears both front and rear.
rear end was a 6k purchase from Currie all new built by them.
front diff was all new gears bearings and seals, local shop.
SOLD!
