Exterior:
-front bumper and tailgate off of a 97 power stroke (vent holes in bumper and smooth tailgate)
-custom retrofit projector headlights with clear turn signals and full clear tail lights (LEDs everywhere)
-debadged, molding removed
-rare leer 100xl camper shell with new 3rd Brake light, carpet, screens, etc.
Suspension:
Custom 4" lift with bulky, discontinued rancho drop brackets, rancho extended radius arms, prococomp coil springs, rough country extended/ braided brake lines, bilstein 5100 shocks.
Interior:
-brand new headliner
-great condition upholstery with RARE full power drivers seat, lighted deluxe sun visors, and auto dim rear view mirror
-kenwood excelon by head unit, Sony/ kenwood speakers, kenwood excelon 600w amp, 12" shallow mount pioneer subwoofer, wireless steering wheel controls.
Drivetrain:
-healthy 351w with new timing chain, lower intake gaskets, timing cover gaskets, water pump, rebuilt injectors, msd cap and rotor, street fire ignition coil, new radiator, new O2 sensors, flow master 40 series out to 3" pipe.
-e4od transmission that shifts great. Fresh service and filter, performance towing valve body, fresh fluid in transfer case.
-freshly rebuilt 8.8 rear end with new 4.56 gears, new posi, fresh bearings, new brake lines, g2 aluminum diff cover.
- new bearings/ ball joints/ bushings throughout front end.
-new steering pump with new tie rods.
-brand new master cylinder and vacuum booster.
Wheels/Tires:
-brand new method double standard wheels/ 85% tread bfg all terrains
Truck is damn near immaculate for its age. I've owned it for 7 years and put in countless dollars and hours. Cleanest OBS ford around.
Cons:
-slight oil leak at rear main seal (hasn't changed since I've owned it)
-slight leak at transfer case (not even enough to drip)
- truck has stock front gears, have 4.56s I'll include but need to be installed, drives fine, just can't use 4x4.
- A/C was removed by previous owner and never bothered to put it back. Heater blows HOT.
Asking $8000 obo
Located in Sacramento Area.
Text or Call me at (707) 363- 6106. Thanks, Brendan
