I have for sale a clean 79 Bronco. Head turner for sure.
Paint is about 3 years old, couple nicks and scratches but in very good condition. Rood is faded. All chrome has been removed and cleaned up. Carpet and rear trim panels out of a 92 Bronco.
Motor is 351M, unsure of miles but runs very strong. Mild cam. Edelbrock intake manifold and 650 carb. Has flow master exhaust. Has C6 trans, and transfer case has been upgraded to BW1356 out of an F350, has a much better 4L gear ratio. Dana 44 Front axle and 9" rear axle.
On 33" BFG All Terrains, American Racing Wheels.
I have taken this to the desert a few times and it does great, keeps up with jeeps and climbs some pretty decent hills.
The bad:
Salvage title is due to break-in from previous owner. Body and frame are perfectly straight.
No A/C needs a recharge, needs heater core hooked up, slight vibration at low speeds from driveshaft not being balanced. Needs alignment. Speedometer doesn't work due to transfer case swap. And the back window motor is a little weak you have to help it up.
Make me an offer, or trade for full-size truck
Thank you.
951 249 4806
79 Bronco
- kylerscharpen
- Bronco Info: 1994 Eddie Bauer Bronco on 35s
- kylerscharpen
- kylerscharpen
Re: 79 Bronco
Bump still available
- kylerscharpen
Re: 79 Bronco
$6000 cash price.
