96 F-250 4 door crew cab Short Bed 7.3 diesel!
93-f1
- Bronco Info: 93-F-150 5.0 Built E4OD. Soon to be class 8000
96 F-250 4 door crew cab, has the 7.3 turbo diesel, 283000 mikes but thats nothing for this motor, trans shifts a little rough just needs new filter which I have will be doing that within the next few days..., oil change and filter 1300 miles ago, fuel filter 1600 miles ago, used factory motocraft filters and delo 15-40 oil. Replaced the 2 high pressure soft lines off the regulator one of them 1000 miles ago the other one 50 miles. Has optional fuel tanks both work well. It gets 18 mpg on the freeway and about 14-15 around town. It is straight piped with a turn down. Just serviced the rear differential, has 286-75-16 bfg all terrains will need new tires shortly, interior is good other than the over drive button hanging. Driver door panel is off to fix the door handle cable, other than that its great, has power everything, cruise control works. clean title, runs great and will tow anything, has a nice stereo deck in it, 2 wheel drive. Only reason i'm selling is i'm looking for a 4wd truck same thing just 4wd. Only open to trading for a 4 door diesel that's 4wd. 7606866198 if your interested asking 6800$ Thanks, Chance.
93-f1
Re: 96 F-250 4 door crew cab Short Bed 7.3 diesel!
More pictures....
