I have a pair of brake rotors: 5 on 5.5, 11.66" diameter, drilled for 5/8 studs, rotor width: 1.25" offset: 1.35", Pilot bore: 4.285" I had them nickel plate so they won't rust
$60 will ship
5 on 5.5, 11.66" diameter, rotors
Trex
- Bronco Info: 1992 bronco, 400hp stroked 302, built transmissions, custom rear bumber, 5/8 studs
