Bronco engine parts
faststang1
Bronco Info: stock 1990 bronco 5.8/ plans for long travel kit from solomotorsports
Bronco engine parts
Post by faststang1 »
Ok I’m selling my a few things off my bronco! I got a pair of Trick flow 170 Twisted wedge smog heads.They only have about 3000 miles on them I had a thrust bearing failure so I decided to build a 408 Windsor instead And I’m gonna need bigger heads
$650 for the pair
I also got lunati roller rocket set for $140.
I got a US shift controller and harness $250
Text me for pics and more info 760-799-7554
Bronco engine parts
Are the heads for a 351w?
faststang1
Re: Bronco engine parts
It came off a 351,But you can put it on a 5.0, you just have to buy the reducers for the smaller head bolts
I forgot to mention that I got A mass airflow meter for 30lbd injectors
I got a complete Edelbrock intake and Plenum The lower truck intake has been ported for these heads The upper is a Mustang 5.0 which outflows the truck upper.It will come complete-with throttlebody and intake spacer and upper and lower intake $900
Masmeter $150
faststang1
alright a little update!
Heads are sold!
still got complete ported intake,intake spacer, 70mm throttle body and mustang EGR spacer 70mm..$900
Us shift $250
if u need pics or info! call or text me
30lbs injectors $250 EV1 plug EV6 nozzles
