Extended Forged 1" King Pin Long Travel Kit
1/2tondiesel
Bronco Info: 1993 Bronco, 4bt + ZF5 swap in progress, frame up resto.
Post by 1/2tondiesel »
This kit was made custom for me by Autofab. It will bolt up to any 80-96 F150 or Bronco or can be adapted to a ranger as well.
Set up has never been used or mounted.
Specs:
Two sets of the rare 1980-81 f150 forged 1" king pin beams were cut and grafted together to make the beams +3 per side.
Radius arms were also extended 11".
Kit includes beams, radius arms, radius arm mounts and bushings, and rare front steer 1" king pin spindles(5x5.5 bolt pattern)
This kit was designed for maximum strength with minimal unsprung weight.
This kit was quite expensive to make and the components extremely hard to find.
$2500 takes it
Interested contact 845-803-1430
Selling to fund my other truck.
1/2tondiesel
Re: Extended Forged 1" King Pin Long Travel Kit
Bump
