Ford 408 and C6
Chachi's Bronco
- Bronco Info: 1992 Bronco,LS6 with 4L80E 4.5" Cho fabricated TTB, speedway full floater 9", 4 link rear on 40" BFG
Ford 408 and C6
I am selling my 408 stroker and C6 trans. I am going in a different direction with my Bronco and will be pulling them out next week. Price for motor $3500.00 and trans price $1500. Or best offer. I will upload photos later today.
Build sheet on 408
F303 cam with Howard's Cams retro fit hydraulic roller lifters.
World Product Windsor Jr. Heads with 1.6 rocker arms. Heads have ARP heads studs.
Stock intake has been matched ported by Greg @ Total Proformance in Santee.
Motor was built last summer and has about 3k miles.
Trans build sheet
2500 stall converter
Welbuild in Oceanside did the planetary gears and drum upgrade & manual valve body. Large oils pan from summit racing. 205 transfer case adaptor.
Was rebuild last summer and has about 3k miles
Build sheet on 408
Trans build sheet
Chachi's Bronco
Re: Ford 408 and C6
Here are some photos from the build of the motor last year.
hollandermotorsports
Re: Ford 408 and C6
Sent a PM
Coltangstadt
- Bronco Info: 1994 Bronco. 351w. Mostly stock
Re: Ford 408 and C6
Can you give me a call or text at 760.917.6707?
cccstrokinitracing
- Bronco Info: 93 bronco , 4' lift on 33" but have been buying parts , 4" over TTB beams, glass ex....
Re: Ford 408 and C6
Is the motor still available ?
Chachi's Bronco
Re: Ford 408 and C6
yes it is just pulled it out this weekend.
Chachi's Bronco
Re: Ford 408 and C6
Here are a few more photos of them now that they are out. I also have the standalone wire harness from Ron Francis wiring for this motor. I also have a spare distributor and also the accessory drive with the ac compressor, power steering pump and alt. The Torque converter is a Hughes performance 2500 stall.
Chachi's Bronco
Re: Ford 408 and C6
I am lowering the price on the motor and trans.
Motor $3000.00 Firm
Trans $1000.00 Firm
Motor $3000.00 Firm
Trans $1000.00 Firm
Chachi's Bronco
Re: Ford 408 and C6
Trans has been sold.
Motor still available.
Chachi's Bronco
Re: Ford 408 and C6
Motor has been sold.
