Ford Parts
Ford Parts
Cleaning out my garage. Too many projects. I'm new here and thought I would post this stuff here first instead of Craig's list.
Will post pictures later today.
1996 Dana 44 IFS third member w/stock gears and stub shaft. Buyer pays shipping. $100
1996 Dana 44 IFS stock inner axles. $40
1982 Dana 44 IFS stock inner axles $40
1992 1356 Borg Warner manual transfer case w/slip shaft style output. It was bolted to e40d out of an F-150. No shifter or linkage. $250
1993 1356 Borg Warner electric transfer case. Needs to be rebuilt. Comes with new motor. $150
Manual transfer case harness connector. Buyer pays shipping. $20
Manual transfer case shifter from e4od. No linkage. Buyer pays shipping. $50
Transfer case boot. Buyer pays shipping. $40.
1993 5.8L stock upper and lower air intake manifold. Does not include vacuum tree. Buyer pays shipping. $50
80's Bronco Ford 9" complete with drum brakes. stock gears. Local pickup only. I don't have a lift at the moment so not willing to transport unless I full dismantle. $600
1996 F-150 grey door panels no cracks. $100
1993 Bronco blue door panels small minor cracks on upper driver side. Local pickup only. $100
1993 stock rear springs and I believe add a leaf with shackles. ~180k miles when removed. $20
1993 stock rear sway bar and hardware. Local pick up only. $10
1996 Bronco set of reman brake calipers in box. Never opened. Buyer pays shipping. $60
1996 Bronco set of used calipers and discs. Surface rust. $20
1994 Bronco sun visors tan color. Mirror on passenger side only. No lights. Buyer pays shipping. $10
(1) 35x12.5x15 with 80 miles on them. 99% tread remaining. Comes mounted on new 15x10 steel rim. Rim was bolted to tire carrier at one point as a spare so has marks from lug nuts. $100
(2) 1994 F-150 5.8 aode HUG2 MAF California computers. $100 each
1994 F-250 5.8 OIL1 MAF e40d California computer. $100
All items located 91750
The years listed are from the trucks that the parts were pulled from.
I work all over So. Cal and can meet as far west as Glendale, as Far East as Banning, and as far south as Murrieta.
Jason
TXT 818.317.4086
Jason
TXT 818.317.4086
Re: Ford Parts
PM sent re: door panels and 35x12.50x15
Thanks!
Thanks!
Ford Parts
96 grey panels considered sold.
Re: Ford Parts
I'll take the e4od shift lever. I'll send pm with info. Thanks
- Ghostwhite
- Bronco Info: 1986 F350, 1979 F150 Ranger, 1983 Ranger, 1997 F350
Re: Ford Parts
I'll take the
Sent you a PM.
Sent you a PM.
Re: Ford Parts
Manual transfer case shifter from e4od. No linkage. SOLD
Re: Ford Parts
Ghostwhite,Ghostwhite wrote:I'll take the
Sent you a PM.
I did not receive a pm from you so I attempted to pm you however its stuck in my outbox.
Re: Ford Parts
Correction on computer descriptions:
(2) 1994 F-150 5.8 4R70W HUG2 MAF California computers. $100 each
Ford Parts
Didn't know 94 F150 came with 4r70w trans. Maybe a mustang 5.0? I thought the 5.8 in the trucks went to maf in cal in 95.
- funinthesun95
Re: Ford Parts
94 was the start of ford running door code U in some f150 U= 4r70w or the start of the upgraded AODE
it was just the evaluation of the AOD to AODE to 4r70w fords way to upgraded same tranny
Ford Parts
1994 F-250 5.8 OIL2 MAF e40d California computer. SOLD
Re: Ford Parts
95/96 bolt style calipers. new set
Re: Ford Parts
Bump.
Need stuff gone.. make offer.
Re: Ford Parts
***** Update
1982 Transfer case boot. $40.
1992 1356 Borg Warner manual transfer case w/slip shaft style output. It was bolted to e40d out of an F-150. No shifter or linkage. $100
1993 Dana44 TTB complete with calipers. $400
1993 1356 Borg Warner electric transfer case. Needs to be rebuilt. $100
1993 5.8L stock upper and lower air intake manifold. $50
1993 stock rear sway bar and hardware. FREE
1993 Bronco sun visors tan color. Mirror on passenger side only. No lights. $10
1994 (qty 2) F-150 5.8 aode HUG2 MAF California computers. $100 each
1996 Bronco set of reman brake calipers in box. Never opened. $60
1996 Bronco set of used calipers. $20
(1) 35x12.5x15 on new 15x10 steel rim.95% tread remaining. Wheel and tire was was used for a month. $100
(4) 35x12.5x15 BFG AT on 15x8 steel rims. Tires are not in the best shape. One needs a patch and they all have TTB wear. $200
Procomp 4-6" lift brackets and lift springs for Bronco / F-150 $200.00
Dropped pitman arm $40.00
Ambulance steering setup for Bronco / F-150. $150.00
Ford Parts
***** Update
1993 Dana44 TTB complete with calipers. Bushings recently replace $400
(4) 35x12.5x15 BFG AT on 15x8 steel rims. Tires are not in the best shape. One has a patch. they all have TTB wear. $200
Procomp 4-6" lift brackets and lift springs for Bronco / F-150 $100.00
All stuff obo
Make and offer and come get it.
All stuff obo
LvSteve
Re: Ford Parts
Where are you located
Re: Ford Parts
La Verne, CA 91750tcinu2 wrote:Where are you located
Re: Ford Parts
***** Update
Ambulance steering setup for Bronco / F-150. $100.00
All stuff obo
All stuff obo
Ford Parts
How many miles on the ambulance steering?
