80-96 4" lift kit $300
Drop bracket 4" lift. Includes drop brackets for a 4" or 6" lift, radius arm drop brackets, drop pitman arm, 4" lift coil springs, rear blocks and u bolts, shocks are still good. Comes with most of the bolts/nuts. Everything you will need for the lift. Looking to get $300 for everything. Located in riverside
Brorunner
- Bronco Info: 1989 Bronco with 302 4x4...just starting my go fast build
Re: 80-96 4" lift kit $300
I will buy it. Can you ship to Monterey CA?
Yeah, I bet I can fit it in a flat rate box. I will try tomorrow.
It's a bit dirty but will clean up fine. Looks like it was only on the truck for a year or so. The shocks still have a good charge to them. The pitman arm is included but not pictured.
$250 w/o shocks
Sold
