Radius Arm Frame Mounts
i have a extra set of radius arm mounts. I had a brain fart today and built two lefts, so I made two rights. I only need one set. 75$ plus shipping im pretty sure i can fit them in a medium flat rate box
-Andrew
-Andrew
Re: Radius Arm Frame Mounts
Spread and heim bolt size?
Pictures are broken
- Bronco Info: currently just a group truck 89 bronco 351 c6 gutted for playing in the sand
they work for me, maybe filtered?Tchajagos wrote:Pictures are broken
i re uploaded them to another host in case
www.UC4X4.com
www.UC4X4.com
all pictures working fine for me.
standard 2.625 spread, 3/4 bolt size. from the frame to center of bolt is 4".
Interested. Message sent I think.
here they are in cad. the parts are keyed together with full overlapping corner joints vs the typical open corner joint.
Are the bolt holes for the frame side matched to existing rivets or holes in the frame, or to be drilled?
ChaseTruck754 wrote:Are the bolt holes for the frame side matched to existing rivets or holes in the frame, or to be drilled?
they do not correspond to any existing bolt holes. My radius arms are longer than usual so they are moved back farther on frame. if there is a need i could make a set that index's off existing bolt holes. i am welding them directly to the frame. i left the frame side solid so if you wanted to bolt them on you can drill them to match any existing holes on bottom of frame.
