Brand new never installed BBK 3503 Twin 61mm performance throttle body. 50 state smog legal and C.A.R.B. approved ( D-245-13 ). For Ford Windsor small block v8 truck motors ( 5.0 , 5.8 , 302 , 351 ). Just get a set of gaskets and you're good to go. Sells for $350 or more. |
http://www.bbkperformance.com/products/ ... odies.html
" All BBK Ford Truck & RV throttle bodies are designed to increase airflow and improve horsepower from between 7-12 HP depending on vehicle and application.
BBK are the world's number one manufacturer of aftermarket performance throttle bodies for late model EFI performance cars and trucks.
All BBK Performance Power+Plus Series throttle bodies are CNC machined from high quality 356 aluminum castings to ensure perfect OEM quality and fit every time. Features like OEM die stamped throttle linkages, double sealed bearings, o ringed throttle shafts and new electronic controlled injection molded plastic gear assemblies for the new modern drive by wire applications, make BBK throttle bodies number one in performance and quality. "
Have pics, but I guess they're too large to upload to GFB
email me at monkeiATjuno . com
New 3503 BBK Ford Bronco F-Series Twin 61mm Performance Throttle Body - $300
monkei
Re: New 3503 BBK Ford Bronco F-Series Twin 61mm Performance Throttle Body - $300
Also willing to entertain trades for EECIV tuning equipment I.E. TwEECer , Moates QH etc.
-Patrick
-Patrick
1996sleeper
- Bronco Info: 1996 2wd f150 autofab beams, coilovers, all terrains on alcoas and 351
Text me 619-607-6909 interested
monkei
Other things I'd be willing to trade for / trade w/ cash for:
96 bronco signal mirrors (esp. driver's side)
ZF SH-47 5 speed
ZF SH-47 5 speed
